Hi thereThis is neat!
Could you make a version with RCA component connectors for the 80 columns and SVIDEO connector for 40 columns?
This way cable could be used with most modern analog to HDMI adapters.
Also, neat thing would be a connection for the second SID from DIN pin 5 or 8.
Would you consider selling only the converter board, so people can make their own cable?
BR,
E.
Hi thereHi
YPbPr.
N.
HiHi there
yes I have my own version from RGB to YPbPr that you tell me about that I have not yet included in the sale to the public because I would like to insert it in the DB9 cover and an extreme assembly is necessary. It is a project of the past year then overtaken by other things.
However, it was my intention to make it because it seemed useful to me (as well as for the Amiga the analogue RGG to YPbPr and SVIDEO) ... but people use a variety of connections (RGB-CVBS-SVIDEO-YPbPr-HDMI) ... so I don't there is only one way
You are certainly not the first person to write to me about this type of connection ..
However it is on my agenda ... and it is already a promise for the near future
B.R
You mean if I can do it with DIN8 male for your rear input that is DIN8 female TTL RGB?Yes I can do itIs this cable usable with a Philips CM8833? The Philips has a DIN connector.
Yes, The Phillips CM8833 has a DIN8 connector (female) as TTL RGB input and a scart for 40 column mode input. If you can create this cable I am interested.You mean if I can do it with DIN8 male for your rear input that is DIN8 female TTL RGB?Yes I can do it
Ok I can do itYes, The Phillips CM8833 has a DIN8 connector (female) as TTL RGB input and a scart for 40 column mode input. If you can create this cable I am interested.
Thank you again!Cable received and works perfectly!
Thanks you!
