Sold Commodore 64 SD2IEC+ Disk emulation with diskswap and reset/root buttons
  • Thread starter Thread starter Gunaguna
  • Views Views 347
Gunaguna
Rating - 0%
0   0   0
Netherlands
Limburg
Commodore 64 SD2IEC+ Disk emulation with diskswap and reset/root buttons.
Asking price 60 euro or near offer excluding shipping.
Easy in use:
  • Insert an SD card containing the appropriate diskette images into the device.
  • Connect the Reader to the cartridge or floppy port of your Commodore 8-bit computer.
  • Boot your computer and use the software on the SD card as you would a physical floppy disk. You can often select and load the software with simple commands.
  • The reader's menu allows you to browse the available diskette images and choose the software you want.
Original product from "the future was 8bit dot com":
NOW WITH 3 BUTTONS – AUTO GENERATE AUTOSWAP FILE
NEW IMPROVED Custom molded high quality C64c/C128/C128D/Vic20 style case with logo!
  • Supports JiffyDos, Geos, Final Cartridge III, Exos, TurboDisk, Epyx FastLoad, Speeddisk and Dreamload Fastloaders.
  • Compatible with D64,D71,D81,M2I and PRG file formats
  • LOAD and SAVE files the same you would with a real disk drive
  • Defaulted to drive 8. EG.. LOAD”$”,8 – Drive ID can be changed via BASIC
