Commodore Amiga 1200 with ACA1234 and Indivision AGA MK3.
Due to overcompletion, I am offering the following Commodore Amiga 1200 for sale.
- Commodore Amiga 1200
- A1200(.net) Special Edition CD32 case
- Kickstart 3.1 (v40.68)
- Revision 1D4
- New capacitors (recapped)
- NOS Amiga mouse
- NEC FDD with new IDE- and powercable
- iComp ACA1234 50MHz 030 CPU with 128Mb RAM and MMU
- iComp Indivision AGA MK3
- iComp Real-Time-Clock
- SanDisk ULTRA CompactFlash 4Gb 30MB/s
- Centuriontech LED-module
- Centuriontech USB mouse module (not installed but shows on the pictures)
- AMIGAstore Keyboard membrane
- Centuriontech rear panel IO shield
It has an ACA1234 accelerator, iComp's flagship and a must-have for WHDLoad! The PCMCIA slot also works, so it you can very easily add programs and software on the CompactFlash using a PCMCIA adapter.
The Amiga obviously works absolutely perfectly. Less than 12 months ago all capacitors on the motherboard were proactively replaced (recapped), a top working system that you will not have to worry about for many years to come. This Amiga 1200 really is as good as new.
In the Amiga is also an Indivsion AGA MK3 placed, with this you can connect the Amiga 1200 to modern screens (such as e.g. your TV) with HDMI and use high resolutions. The HDMI connection is beautifully concealed at the rear.
The original RF shield has been removed. In its place is a solid (0.8mm) stainless steel panel mounted from Centuriontech that holds the motherboard firmly in place in the case. Underneath the motherboard is a brand new insulation membrane.
If you want a perfect looking and working Amiga 1200 and relive the days of yesteryear then you want this one! From a smoke free and pet free home.
Asking € 1200 + shipping + Paypal fees.
It will be shipped via a signed for and insured courier service.
Edit: Payment received from @asregg339.
Going to send it on Monday as agreed with buyer.
- Revision 1D4
- NOS Amiga mouse
