Closed Commodore C64SD v2.0 Infinity card **REDUCED TO CLEAR**
  • Thread starter Thread starter Sardine
  • Replies Replies 12
  • Views Views 3006
Sardine
Staff member
Staff Moderator
Donator
England
Merseyside
Here I have my Commodore C64SD v2.0 Infinity card with 2GB SD Pre-Loaded with Mano's 2GB Image.
Basically you can run all your software from an SD card on CBM 64/128
http://www.manosoft.it/?p=1〈=en
Item comes complete with all boxes, accessories, and manuals.
Works perfectly and I tested with Jiffydos also with "f1" and "shift - RunStop"
for those that don't know the C64SD Emulates a 1541 drive but the capacity can be huge, I use a 2GB card in mine and with a small loader program i can browes the SD card from my C64, open a disk image and select the PRG file inside and run it, Works flawlessly.
As with all Hardware of this age you are buying as is(Even though this is less than a year old). If you require more pictures or a video I can do at request when i have the time and space to setup again.
I'm looking for £45 + P&P + Fees or Gift
This is now on Ebay BIN + enough to cover Fees
Hello
Hello
I have one of these and they are fantastic. Real easy to use. A must for any 64 owner. Good luck with the sale.
thanks for the link as that site has some cool gear!
good luck with your sale
Price drop (Forgot Euro to £) was way too expensive sorry.
Are there any games, which dont work with C64SD due to not true full cycle exact emulation of 1541 disk drive? Thanks.
no idea, all the games i tried worked.
For example Newcomer (it uses an own disk format) and some demos (demoscene). I have the same card (really like it) and the d64 format games I tried work just fine.
Best,
Attila
According to the C64SD Manual, the C64SD uses the same firmware as the SD2IEC devices. Because of this, it has the same compatibility as the uIEC/SD and SD2IEC.
Hope this helps. :thumbsup:
Heather
