Edit: yer I think i Just need to change the jumpers, OK thanks.
Also what program did you use to write the .d64 files with & is there a guide?
Yes change the device id. Some programs might require to be loaded from device 8 using a real 1541 (or "more" real than the emulation c64sd provides), so you might need later to switch back and forth ids.
I used the cbmcommand program to copy the images to disks. On manosoft.it there is a download section, from there the file "Original Package for SD - C64SD-V2.0-04-2012" (~110MB) contains everything (fastloader, browser, some games and utility) to get started.
Best,
Attila
