Copy files and keep original dates/times
  • Thread starter Thread starter JHanna
  • Replies Replies 15
  • Views Views 543
JHanna
Northern Ireland
Hi all.
As per title, wondering how to copy files from an old hard disk to a new one on OS3.2.2 whilst retaining original date and time of files.
Does dragging and dropping keep original file attributes? Or do i have to do it another way?
Thanks!
Hi all.
Thanks!
Try Dopus v4 onwards (Directory Opus), there are settings to allow for what you want to achieve.
In AmigaOS "#?" does what "*" does in Linux (and all Posix OS I think").
In a simple explanation it means "everything". Asterisk is also used in regular expressions meaning "0 or more" occurrences of any character.
PS:
I emended my previous comment, you don't need "#?" in the destination, only the Disk where you want to copy all the files, so in your case "DH1:"
No. As you will have a syntax error 👍🏻 AmigaDOS uses both for Wildcard like as explained the “*” in both DOS and UNIX/LINUX OS.
According to examples 4 and 5 on the page I’ve linked above, you do not need wildcards/patterns if you specify ALL when copying disk/directory.
To preserve the original dates, you need to include DATES switch, and to preserve all attributes including dates, the CLONE switch.
So
copy sdh1: dh1: clone all
should do the job.
So
should do the job.
Cheers!
Please let us know how quickly the copying worked, and if it worked at all the way you wanted.
I believe using of option QUIET could speed it up.
QUIET stops it displaying the information on the screen so should speed up the operation.
