CSA mega midget & whdload FIXED
  • Replies Replies 11
  • Views Views 2644
mjnurney
we live as we dream. Alone.
england
Towcester
now I've run my mega midget on my A500 (+) and a GVP HD8 (8mb) with no problems at all , the only issue ever was very , very slow cd access..and huge amounts of desk space being used...
The A500 was used as a WHDLOAD machine with a MMR 68030.
in fact the A500 ran better if the MMR was not using its own fast ram (SRAM), hence much slower..
i could even run whdload games from CD!
WB 2.1
a500 spec.
1,5 mb chip
8 mb fast (via gvp HD8)
But..
On my a 2000
i get the following errors and it just locks up the Amiga if the SRAM fast ram is not enabled on the MMR.
cannot allocate EXPMEM
object in use
cannot load "yyyyyyyyyyy"
recoverable error occurred
complete lock up at the 'registered to ..." screen
A2000 spec
2mb chip (mega chip)
8 mb fast (same ram as was in the A500) or set to 4mb - no difference
WB 2.1, 3.1
I think the A2000 GVP HD8C does not play nice with the MMR ...unlike the HD8+ of the A500.??
now unless there is a MMR command to add on or a ROM update for the GVP i cannot easily think on whats wrong here...
The fast ram is configured as 24bit public fast ram not 32 bit as the MMR does not have a ram board.
---------- Post added at 22:37 ---------- Previous post was at 22:31 ----------
from Amiga.org
I can say for certain that the csa-mmr and gvp series II scsi controllers don't work together. No way no how. I've use suprascsi and trumpcard with no problems. The csa-mmr *may* work with a gvp series-1 controller as they were only pseudo-dma. I haven't tried this combination. I would disable the scsi card and make a boot disk to determine that the rest of the system is playing nice together.
UPDATE
after many hours of prodding and poking, I've found the error - nothing at all to do with the mega midget.
The GVP SCSi card had a bad ram module and was throwing up random and not so random error. I've since temporally changed the simms for another set and all the problems have now gone or seems to of. fingers crossed.
The GVP ram check confirms this ..
with the old (bad) ram in i check RAM FAIL - FFFFFFFF should be blah blah blah
with the other ram in get RAM PASS - CHECKING..
and so on.
AND
WHDloads loads!!!
5Th gear
Abandoned places
Alien Breed
Bomb jack
more to test but its looking good :-)
Thanks Chris..
They don't seem to make any difference really.
Mostly the jumpers are timing wait states for the ram board and crystal settings..
I had this problem when I had a mega midget. It was the slave being split between the 2 different memory segments. I can't remember how I solved it at the moment.
Later,
dabone
If you remove the GVP HD card, and boot from floppy with the MMR program/command to add memory, does it work and load into Workbench then?
In the 90's I ran an 030 MMR with A2091 and then Octagon SCSI card, and had no problems except for SCSI lockups (for another conversation on another day. I never resolved the SCSI lockups)
You know what, if i remove the MMR and just boot to a 68000 or 68010 the same thing happens,
either the GVP is playing up or the RAM has issues...
---------- Post added at 17:35 ---------- Previous post was at 16:43 ----------
PROBLEM SOLVED (i think)
---------- Post added at 17:51 ---------- Previous post was at 17:35 ----------
PS I need simms ASAP :-)
I've posted a Wanted add on the thread :-)
i know , i know .... (bows head in shame) but the ram was okay a month ago???
anyway ...time to get a 50mhz cpu bolted in the MMR :-)
not sure you'll be able to run it at 50MHz without requiring a firmware update to the MMR: IIRC it will only be stable at up to 38MHz...
Can't quite recall why I think that.
Anyhow, when's the next curry? :D
funny you should say that it does run stable at 38mhz but not 40mhz ....
i suppose firmware is impossible to find? CSA sold a 50mhz version didn't they?
---------- Post added at 23:06 ---------- Previous post was at 23:03 ----------
Amiga.org
Re: CSA Mega Midget Racer
I have two original CSA mega midget racers in A500. They run just great at 50mhz, that is what they were configured for when I purchased them new.
hmm... The co processors run at 50MHz quite happily. I think there was something about a limited edition for 50MHz stability. Will see if I can find more out/
That's true my friend , but ram maybe am issue as I've bought a graphics card. So I may have to upgrade anyway to get some ram capacity..
I'm limited to 8mb fast at the min.
