For Sale Custom made case for Amiga 4000 - pre order
  • Thread starter Thread starter arymanx
  • Replies Replies 96
  • Views Views 18993
(Marked as sold/completed by arymanx)
Declaring interest for one case. RAL9005 ripple, plain top.
FYI for anyone ordering a power supply to use with this case.
The Corsair SF450 that @arymanx recommends is no longer manufactured by Corsair. I ordered the new Corsair SF750 supply to use instead, but that supply doesn't output the -12V the Amiga 4000 needs for sound. Now to track down a different SF supply that does supply the -12V.
No complaints with the case though - it's excellent!
Thanks for the comment. No sure if that is fully true. I do not own personally SF750, but I managed to find picture and it looks like it is present, I also checked manual.
ATX/SFX ditched while ago -5V which is used in A3000D/A3000T and A2000 (-12V is also needed).
Could you please check label on your PSU, take picture and post it here?
I can confirm newest Corsair SF range switched to ATX3.0 standard and adopted Type5 cables.
-12V is missing and smaller pitch connectors are used.
I can still build these type of cabling with integration of negative voltage module. But it was easier and cheper for the previous models.
Here is the picture from the box of the the Corsair SF750 that I ordered directly from their website:
No -12V line is listed on the box, although I didn't notice that detail at first. After connecting the PSU to my A4000, I didn't have any sound, and measuring the -12V line with a multimeter directly where it feeds into the A4000 confirmed that lack of -12V.
I just barely ordered and received a Lian Li SP750 which fits the case perfectly and supplies the required -12V voltage. The Lian Li was less expensive than the Corsair PSU as well! :)
Reviews of the build quality of the Lian Li supply confirmed that it is a high-quality supply.
in case more cases are planned, pls. count me in.
I actually have 3 cases available almost straight away. Powder coated Ral9005 ripple, just need to do final assembly. It may take 2-3 weeks due to limited spare time., but will try to sort it out ASAP. Please contact me via PM.
I received my case the other day. It's a piece of art. Highly recommend. Thanks a lot!
  1. Unimatrix
  2. Picard
  3. DocLeisure
  4. Grim82
  5. Bandaren
  6. daver
  7. Timtheloon
  8. Dege
  9. 4MlGA
  10. Xanxi
  11. Radocaj
  12. 4MlGA
  13. Pbjr
  14. 0001agima
  15. Davka
  16. dingebre
  17. SantiDarkG
  18. Telsar
  19. sbrentson
  20. yugorin
  21. toddbailey
  22. Quazza
  23. Detordiggei
  24. Szmn
  25. nickrb
  26. CP_997
  27. ferrumm
  28. Lamaman1971
  29. ajrade
  30. sandlbn
  31. ShootTheCore
  32. ori1a
  33. techdyne
  34. doncheffo
  35. DavidL
  36. C16Oli
  37. ajwhix
  38. AmigaPNW
