Ok, so here's an update regarding this item....
As promised, I went on to test it a bit more and post some new pics. Even went a bit to far and bought an old VGA CRT to hook it up to this thing.
As I was fiddling with it, wires soldered to the daughter board which is attached to ALICE broke loose and took the pads with them as well (daughter board runs VSYNC and HSYNC signals from ALICE chip to the main PCB).
So I had to fix the daughter board somewhat. While at it I wanted to improve the thing so the wires have much less chance of getting pulled out again.
Therefore I've drilled two holes through the daughter board and ran the wires through them so the holes act as a strain relief - this is much more sturdy now than the original ever was.
Also repaired the connection on the bottom side as the pads have been damaged as well - not my finest hour with the soldering iron but it works.
Noticed the PLCC socket on the daughter board had a small crack (everything was still working fine but it had been cracked and would go sooner or later), so i replaced the socket with a new, quality 3M one.
Here's the picture of how it looks now (mounted in A4000):
And now some more pictures for comparison, as requested:
