Closed Delfina Lite Soundcard
AlCarbonara
Germany
Bavaria
I have one soundcard delfina lite for sale:
  • DSP
  • Motorola DSP56002 @ 40 MHz
  • 24 bit data bus - 24 dB dynamic range
  • fully programmable using the supplied software
  • memory
  • 96 kB, 24 bit SRAM, not expandable
  • one half of the memory can be addressed in program and X data space, the other half only in Y data space
  • zero-waitstate, 12 ns
  • audio
  • Crystal CS4231A audio codec
  • sample frequencies up to 48 kHz at 16 bit
  • three stereo inputs (2 RCA, 1 internal CD-ROM), one stereo output (RCA)
  • all inputs can be mixed with Delfina's output
  • full duplex recording and playback
  • AHI driver
  • optional serial interface module - DelfSer
  • connects to Delfina's expansion connector (DelfExp)
  • maximum serial speed is 625000 bps (1/64th of the DSP clock rate)
  • lower speeds are generated by dividing the maximum speed by an integer
  • DB25 serial connector
  • can be ordered with 100% Amiga compatible serial port - including -12V and +12V power - otherwise these signals are simply cut
  • allocates a buffer of its own in Delfina's memory, so using DelfSer may disable some memory hungry DSP effects
  • a 24 bit S/PDIF digital I/O was also planned for DelfExp, but never released
  • notes
  • 8 bit Zorro bus interface logic - when running many sound outputting programs at the same time, the system may feel slow responding
You will get the soundcard full tested and working with the software on cd.
200.- € + (s+h) + paypal-fees !!!
CU,
AC
