DIY CD32 joypad adapter for Sega 6-button pads
  • Thread starter Thread starter robinsonb5
  • Replies Replies 8
  • Views Views 5427
robinsonb5
England
Norfolk
Tonight I've got the first of my planned CD32-controller projects working.
The PIC I've used here is a 16F887 which with 40 pins is way larger than I need for this project, but the smaller chips I've ordered haven't arrived yet!
(The 887 will probably eventually get used in a two-player project of some kind. Emulating *two* CD32 pads in a single PIC should be a fun challenge!)
What I like about these chips is that (a) they're cheap (amazingly, cheaper than the two discrete logic chips that are normally needed in a CD32 pad!), and (b) they're completely self-contained. Everything on the breadboard to the left of the chip is only there for diagnostics, and can now be dispensed with.
So far I've only handled the buttons - the directions aren't yet passed through, but that's a trivial addition.
Mapping-wise, the start-button obviously maps to the CD32's Play/Pause button, but the other mappings are slightly less obvious. I've mapped X and Z to the shoulder buttons, and then mapped B to Red, C to Blue, A to Green and Y to Yellow.
Once I've got the directions working and built a "real" on on stripboard I'll post the PIC source and pinouts in case anyone wants to have a go at making one :)
hi mate great project you got going there could this be used on an arcade stick too as i am building one so far i am using 2 ps2 pads to usb for mame
and will be wiring it up for the amiga too but only 1 button
and i would love to use the other buttons
see here
https://www.amibay.com/showthread.php?t=20515
Yup, very easily. In the case of an arcade stick the PIC wouldn't have to know about the direction lines, so you'd wire those directly, and just route seven of the fire buttons to the PIC, then wire the PIC to the Amiga's three fire button lines. The program in the PIC would obviously have to be slightly different, but it'd be a pretty simple change.
Yup, I saw that - nice project! :thumbsup:
Nice job, I'll definitely be having a go at building one of these.
At last - time to play with such projects! (So much geekery, so little time!)
Here's the PIC assembly source for the adapter, based on PIC16F886 - though it should be easy enough to adapt to similar chips:
Code:
; CD32 Serial Shift Register, software implementation for PIC16F88x
; Copyright (C) 2011 by Alastair M. Robinson
    processor 16f886
    include <P16F886.INC>
    __CONFIG    _CONFIG1, _INTOSCIO & _DEBUG_OFF  & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_ON
    __CONFIG    _CONFIG2, _WRT_OFF & _BOR21V
#DEFINE    BANK1    bsf    STATUS,RP0
#DEFINE BANK0    bcf    STATUS,RP0
RAMSTART         equ    0x20
COMMONRAMSTART        equ    0xf0
CD32_SEL        equ 0    ; In port B, to make use of edge-sensing interrupt.
CD32_CLK        equ    4    ; The rest of the CD32 lines occupy port A
CD32_DATA        equ    5
CD32_UP            equ    0
CD32_DOWN        equ    1
CD32_LEFT        equ    2
CD32_RIGHT        equ    3
CD32_DIRECTIONMASK    equ    0x0f    ; 00001111
CD32_BUTTONMASK        equ    0x30    ; 00110000
Sega_SEL        equ    4    ; The Sega pad is wired to port B
Sega_D0            equ    7    ; Up
Sega_D1            equ    5    ; Down
Sega_D2            equ    3    ; Left
Sega_D3            equ    2    ; Btn 2
Sega_D4            equ    6    ; Btn 1
Sega_D5            equ    1    ; Right
                    ; Sega bit allocations, mapping to CD32 serial shift register
Sega_A            equ    4    ; Green
Sega_B            equ    6    ; Red
Sega_C            equ    7    ; Blue
Sega_Start        equ    1    ; Play/Pause
Sega_Down        equ 5    ; Yellow
Sega_Up            equ    3    ; Right Shoulder
Sega_Left        equ    2    ; Left Shoulder
Sega_Right        equ    0    ; Zero
Sega_DIRECTIONMASK    equ    0x2d    ; 00101101
Sega_BUTTONMASK        equ    0xd2    ; 11010010
tmpval            equ    RAMSTART+0
shiftcounter        equ    RAMSTART+1
count1            equ    RAMSTART+2
count2            equ    RAMSTART+3
segastatus        equ    RAMSTART+4
segatmp            equ    RAMSTART+5
portalatch        equ    RAMSTART+6
portatmp        equ    RAMSTART+7
int_status        equ    COMMONRAMSTART+1
int_w            equ    COMMONRAMSTART+2
shiftreg        equ    COMMONRAMSTART+3
    org 0x00
    goto    start
    org 0x04    ; Interrupt routine - very time critical since we're
                ; simulating a serial shift register.
    ; Save regs
    movwf    int_w
    swapf    STATUS,w
    movwf    int_status
    BANK1
    bsf    TRISA,CD32_CLK
    BANK0
    ; The first bit should already be present since the
    ; first bit represents the Blue button, which is the
    ; data line's normal function.  FIXME - can we improve compatibility by not putting
    ; the Blue button on the line until this point, or would it be too slow?
    ; We don't bother to watch the Select line, instead we
    ; let the watchdog timer rescue us if the comms break down.
waitclkhigh
    btfss    PORTA,CD32_CLK
    goto    waitclkhigh
    ; Put next bit on the data line - inverted by transistor
    btfss    shiftreg,6
    bsf    PORTA,CD32_DATA
    btfsc    shiftreg,6
    bcf    PORTA,CD32_DATA
waitclklow
    btfsc    PORTA,CD32_CLK
    goto    waitclklow
    ; Shift 1 bit left
    rlf    shiftreg,f
    clrwdt
    decfsz    shiftcounter,f
    goto    waitclkhigh
waitselhigh
    btfss    PORTB,CD32_SEL
    goto    waitselhigh
    bcf    INTCON,INTF
    ; Restore port A
    BANK1
    bcf    TRISA,CD32_CLK
    BANK0
    movf    portalatch,w
    movwf    PORTA
    ; Reset shift counter for next time
    movlw    0x07
    movwf    shiftcounter
    ; Restore regs
    swapf    int_status,w
    movwf    STATUS
    swapf    int_w,f
    swapf    int_w,w
    retfie
start:
    ; Set internal oscillator to 8MHz
    movlw    0x70
    banksel    OSCCON
    movwf    OSCCON
    ; Initialise port B for digital input, except for SEL pin
    ; We also set port A to high Z
    banksel    PORTA
    clrf    PORTA
    clrf    PORTB
    clrf    PORTC
    ; Get rid of any interference from ADCs
    banksel    ANSEL
    clrf    ANSEL
    clrf    ANSELH
    banksel TRISA
    movlw    0xff
    movwf    TRISB
    bcf    TRISB,Sega_SEL
    clrf    TRISA
    clrf    TRISC
    ; Enable weak pull-ups on Port B
    banksel OPTION_REG
    bcf    OPTION_REG,NOT_RBPU
    bcf    OPTION_REG,INTEDG
    banksel WPUB
    movlw    0xfe
    movwf    WPUB
    banksel PORTA
    movlw    0x07
    movwf    shiftcounter
    banksel WDTCON
    movlw    0x1    ; Shortest WDT delay possible (without touching prescalers?)
    movwf    WDTCON
    banksel INTCON
    bcf    INTCON,INTF
    bsf    INTCON,INTE
    bsf    INTCON,GIE
    banksel PORTA
    clrf    PORTA
    bsf    PORTB,Sega_SEL
    call    shortdelay2
loop:
    BANK0
    call    getsega
    ; Decode directions
    movlw    CD32_DIRECTIONMASK
    movwf    portatmp
    btfss    segastatus,Sega_Up
    bcf    portatmp,CD32_UP
    btfss    segastatus,Sega_Down
    bcf    portatmp,CD32_DOWN
    btfss    segastatus,Sega_Left
    bcf    portatmp,CD32_LEFT
    btfss    segastatus,Sega_Right
    bcf    portatmp,CD32_RIGHT
    movf    segastatus,w
    andlw    Sega_BUTTONMASK        ; On the first read, only A, B, C and Start are readable
    movwf    tmpval
    call    getsega
    call    getsega
    call    getsega
    movf    segastatus,w
    andlw    Sega_DIRECTIONMASK    ; Now we have X, Y and Z on the direction lines
    iorwf    tmpval,w
    iorlw    0x01            ; Set lowest bit of shift register, which is constant
    movwf    shiftreg
    ; Mirror Red and Blue status directly to PORTA
    btfss    shiftreg,Sega_B        ; Red button on clock line
    bcf    portatmp,CD32_CLK
    btfsc    shiftreg,Sega_B
    bsf    portatmp,CD32_CLK
    btfss    shiftreg,Sega_C        ; Blue button on data line - inverted by transistor
    bsf    portatmp,CD32_DATA
    btfsc    shiftreg,Sega_C
    bcf    portatmp,CD32_DATA
    movf    portatmp,w
    movwf    portalatch
    movwf    PORTA
    clrwdt
    call    longdelay
    goto    loop
getsega    ; Return button status in segastatus
    movlw    0xff
    movwf    segastatus
    movf    PORTB,w
    movwf    segatmp
    btfss    segatmp,Sega_D4    ; B button, map to Red
    bcf    segastatus,Sega_B
    btfss    segatmp,Sega_D5    ; C button, map to Blue
    bcf    segastatus,Sega_C
    btfss    segatmp,Sega_D0    ; Up
    bcf    segastatus,Sega_Up
    btfss    segatmp,Sega_D1    ; Down
    bcf    segastatus,Sega_Down
    btfss    segatmp,Sega_D2    ; Left
    bcf    segastatus,Sega_Left
    btfss    segatmp,Sega_D3    ; Right
    bcf    segastatus,Sega_Right
    bcf    PORTB,Sega_SEL    ; Drop select line
    call    shortdelay2
    movf    PORTB,w
    movwf    segatmp
    btfss    segatmp,Sega_D4    ; A button, map to Green
    bcf    segastatus,Sega_A
    btfss    segatmp,Sega_D5    ; Start button, map to Play / Pause
    bcf    segastatus,Sega_Start
    bsf    PORTB,Sega_SEL    ; Raise select line again
    call    shortdelay2
    return
shortdelay2    ; Preserves W
    movwf    count2
    movlw    0x10
    movwf    count1
    clrwdt
shortdelay2loop
    decfsz    count1
    goto    shortdelay2loop
    movf    count2,w
    return
shortdelay    ; Preserves W
    movwf    count2
    movlw    0x3f
    movwf    count1
    clrwdt
shortdelayloop
    decfsz    count1
    goto    shortdelayloop
    movf    count2,w
    return
longdelay    ; Doesn't preserve W
    movlw    0x18
    movwf    count2
longouterloop
    movlw    0xff
    movwf    count1
    clrwdt
longinnerloop
    decfsz    count1
    goto    longinnerloop
    decfsz    count2
    goto    longouterloop
    return
    END
Stripboard layout to follow.
As promised, stripboard layouts!
Two different layouts here, one with and one without the pulldown transistor. The transistor's only needed for certain stubborn motherboards which won't register a logic low from a CMOS microcontroller pin. (If you've had trouble with the right mouse button on a PC mouse adapter, yours is a stubborn one!)
Note that if you build the version without pulldown transistor, you'll need to reverse the sense of two tests in the code: exchange the "btfss" and "btfsc" on lines 86 and 88, and do the same again at lines 217 and 219.
(Not shown on the layouts, but hopefully obvious - you need to break each track of the stripboard between the legs of the chip!)
hi mate which one did you send me to test
Neither! These are specifically for decoding a single 6-button Sega Megadrive pad, and making it usable on a CD32.
I'll make a new thread for the one I sent you when I get a moment :)
