A good point was raised in this thread about Transfer Speeds and CPU Load.
IDE, by its definition is a Programmed Input / Output (PIO) is very CPU intensive.
Using the Native IDE and GVP's Fast SCSI 2 (DMA) as an example
In the above test, we are using a stock 7.4MHz 68000, this achives 1.67MB persecond with just over 7% CPU load to achieve this.
CPU : 68000 @ 7.4MHz
RAM : 8MB of FAST RAM
DMA : YES
FFS : Standard FFS Format
KS? : Kickstart 3.1
OSx : Classic Workbench
This is an Apollo 030 Mk3 with 64MB of RAM running on an A1200, as you can see it manages about 1.64MB per second, only slightly slower than the GVP - however as you can see it has a CPU load of over 99% so the CPU is spending all of its time transfering data as opposed to processing it.
CPU : 68030 @ 40MHz
RAM : 64MB of FAST RAM
DMA : NO
SFS : Smart File Format
KS? : Kickstart 3.1
__________________________________
If we were to work out the processing load one could look at a simple method as this
68000@7.4MHz = 0.9 MIPS - achieves - 1.67MB Per Second Transfer @ 7% Load
Equates to [ 0.063 MIPS per 1.67 MB Per Second ]
68030@40MHz = 8.5 MIPS - achieves - 1.65MB Per Second Transfer @99% Load
Equates to [ 8.42 MIPS per 1.4 MB Per Second ]
to put this into contrast my 060@50Mhz (64MB RAM) provided the following
68060@50Mhz = 65.2 MIPS - Achieves - 1.87MB Per Second Transfer @ 45.6% Load
Equates to [ 29.34 MIPS per 1.8 MB Per Second ]
As you can see a non-managed / off loaded solution is quite detrimental to the workings of the CPU as it spends more time (processing power) in fetching data as opposed to processing it.
In the case of the 060 above we can see an extreme case where the CPU has work increasingly harder to maintain throughput of data. Arguably the result shows that I am using the processing power of an 040@40Mhz to achieve a piddly 1.8MB Per Second Transfer
On the flip of this
Cyberstorm Mk2 060@50Mhz + 128MB of RAM + DMA SCSI
68060@50Mhz = 65.2 MIPS - Achieves - 7.4MB Per Second Transfer @ 28.3% Load
Equates to [ 18.45 MIPS per 7.4 MB Per Second ]
Interestingly, while we have a much faster transfer Rate I am still using the processing power of an 040@25Mhz to achieve this result.
So in a nut shell, there;s more to transferring data, it is how it is transferred.
(sorry for the lack of pictures on the last to two - sadly I lost them =( )
