AmigaDepot
What a great piece of work ! Thank you for sharing with us.
Yes, assuming the zorro cards are half length* and / or do not require use of a rear bracket that a pci card needs.Is it possible to use simultaneously all PCI slots and all Zorro III slots?
Very interested in a AA3000+ firebird for checkmate case!!I've been asked to do a revised version of Firebird daughterboard that fits to the A3000 motherboard housed in a Checkmate 1500 case.
Some info about A3000 motherboard in Checkmate 1500 case here.
I'm gauging how much interest there would be for a Firebird A3000 Checkmate edition daughterboard.
Do you have a Checkmate case with A3000 mounting kit?
Would you be interested in a Firebird Checkmate daughterboard for A3000? Or for AA3000+? Or both?
You could either post your interest here or by private message.
Best source also for such questions might be the EAB and the thread over hereOkay, via successful scouring, i found prmscan, openpci.library, and prometheus.library 4.1 and was able to run prmscan against my two Radeon 9250 256MB boards. However, i'm seeing the boards only scan as 128MB - is this expected? Is the RAM potentially partitioned such that 128MB is accessible over PCI, and the other 128MB is "frame-buffer" video memory?
Both boards come up as:
prmscan 1.7 (05.1.2010) ...
prometheus.library version 4.1
PCI cards listing:
Board on bus 0, in slot 2, function 0
Vendor: ($1002) unknown ($1002) <-- THIS IS AMD/ATI
Device: ($5960) unknown ($5960) <-- THIS IS RADEON 9200 PRO / 9250
Revision: 1
Device class 03, subclass 00.
BAR0 address range: 60000000 - 67FFFFFF (128 MB)
BAR1 address range: 7FE01000 - 7FE010FF (256 B)
BAR2 address range: 68000000 - 6800FFFF (64 kB)
128 kB of ROM at 68020000 - 6803FFFF.
Board driver: NONE
Where did you scour these from?Okay, via successful scouring, i found prmscan, openpci.library, and prometheus.library 4.1 and was able to run prmscan against my two Radeon 9250 256MB boards. However, i'm seeing the boards only scan as 128MB - is this expected? Is the RAM potentially partitioned such that 128MB is accessible over PCI, and the other 128MB is "frame-buffer" video memory?
PCI cards listing:
Revision: 1
Board driver: NONE
ThanksTry the first post of the Sonnet thread on EAB, or looking in this thread at the various links
Have a look at post #43 of this sales thread:Hi,
I'm traying to run Killer K1 with Sonnet library. I'm using powerpc.library version 17.14 which supports Prometheus.
After call InitPPC I get message "e300 based PPC cards currently not working correctly!". According to documentation this card should work.
Has anybody run this card in Firebird PCI?
www.amibay.com
I checked and there are this components.Have a look at post #43 of this sales thread:
For Sale - Firebird PCI Daughterboard for Amiga 4000D
Update List 1.fgh 2.qz3fwd 3.a1200freak 4. 5.OffseT 6.Buflash 7.Picard 8.Vasilii 9.dw0ntU5m3 10.timmie 11.joachimrs 12.nirn 13.L3rd 14.sandlbn 15.Buflash 16.warr8or29 17.maurizio54mau 18.Telsar no more acceptedwww.amibay.com
I believe the Firebird has to have the correct components in place.
I configured it with this manual and other boards works correctly.Also have a look at the Thread on Prometheus Firebird setup I put together. Just in case you are missing something which can be found over in Amiga.org here:
Basics for Setting up Firebird (Prometheus) A4000 3000 Daughterboard - Page 1
Basics for Setting up Firebird (Prometheus) A4000 3000 Daughterboard - Page 1forum.amiga.org
What about the picture in post #43. Does your board have that same component make up?I checked and there are this components.
Yes, it has. But I see that PPC board works but are some lags for example when loading workbench pattern.What about the picture in post #43. Does your board have that same component make up?
