Fix amiga 1200 yellow screen
  • Thread starter Thread starter soviet9922
  • Replies Replies 13
  • Views Views 3650
soviet9922
uruguay
montevideo
Hi guys, a friend of mine asked me if i can fix an amiga 1200 that he got recently for him.
The motherboard is a 1200 rev 2b motherboard.
Testing the bare motherboard only, no accelerator or anything just monitor and power (the psu is an atx psu and is working on my 1200).
I always got a yellow screen at power on.
Any tips on fixing this are welcome !.
If you don't have any multimeters or an oscilloscope its going to be hard, however yellow screen leads to possibly a CPU issue.
Yes i have a multimeter, logic probe and also 100mhz oscilloscope i purchased it recently and only learning how to use it, but if you can point me to what i have to look for on the board i could follow up.
Diagrom os your friend:), if you have acccess to a couple of 27C400 eproms and can burn Diagrom to them, link below
http://www.diagrom.com/
Thanks! that sure the first thing that i will check out
Ok after checking the board was full of flux everywhere after a very deep cleaning the yellow screen goes away but now i have a green screen (chip ram).
Using the diagroms i got this:
small video showing the colors and serial output from diagrom:
https://www.youtube.com/watch?v=Km6aRZVArGA&feature=youtu.be
inserting a fast ram expansion got me other random results tried just turning on pressing left mouse button and right mouse button:
heads or tails online
Green screen is a Chip RAM fault, I suggest you check all RAM Chip connections. Why was the board covered in flux, was it repaired previously?
The guy that was the original owner of the board tried to "reflow" the board using a hot air station.
He obviously covered it in 1 liter of yellow stick flux and heated the chips up, of course he don't fixed the issue.
Now he told me that he was getting green screen before the reflow operation so think the yellow screen was caused by all the flux.
I checked the pins on the rams and most ics using the microscope and i don't see any bad solder joints at least on the ram and main ics.
Have you been over the chips with a multimeter to check the VCC pins are all getting the correct voltage? You may have a bad RAM chip. Do you know anyone with an oscilloscope that can help you to check the data lines on the chips?
I didn't check the vcc lines on the ram chips, checked on the powersupply line and they same to by fine. The power supply is an ATX and work fine on my amiga 1200.
Will check the pins on each chip anyway.
Yes i recently got a 100 mhz oscilloscope so i can look for the waveforms if you can tell me where i have to check and what to look for ?.
verify all pin solder of gayle and other big chips
burn 2 27c400 with Logica diagnostic
Flux doesn't conduct, so it's unlikely that the flux was the issue. Possibly reseating the socketed IC's when you cleaned the board could have caused the change from yellow to green. As well as that, if he didn't know what he was doing with the hot air station, he may have fried some chip from the heat.
Bryce.
Bryce.
Now about the flux, i have in the past tested home build boards and computers and have glitches and things happening until i cleaned the flux, flux is not conductive but why it can make this kind of problems ?.
For example in this video the 8 bit guy have the very same issue until he cleans the flux from the board:
https://youtu.be/KAivGLHJzJM?t=1019
It all depends on the type of flux you used. Rosin based fluxes are non-conductive unless you heated it so much that it turned black at which point it is full of carbon and will create a resistor. The other possibility is that there were also microroplets of solder in the flux and these were creating little capacitors all over the board. Generally, it's always a good idea to clean a PCB after building it anyway.
Bryce.
