According to the website, no. I could not get it to run at all on win 7 64bit. But installed a small winxp partition and that seems to work fine (at least the test button does)
Software Tested on XP 32bit working fine ... but for some reason if you have more then one (CPU) core must disable the others.. to work in full speed and without errors..
Tested on Dell 270,280 without problems (P4 2.8G)
dell 745 with one core disabled.. work ok
and in some laptops (always disabled the extra cores) ..
paraller port work perfect in ps2 or standard mode from bios
Version 1.2 says work with external paraller port card.. i have tested 2 none of them work..
ALWAYS use computer with internal paraller port!
I will try to build a shell to work the software in 7,8.1 windows (any version) ... but i'm in 60%.. i will post this software when is ready (always as freeware)
Windows 10 not support floppy drive !!!!!!!!!!!!!!!!!!!!!!!
