For Sale Fujinet for Apple II, FujiApple customized tiny sized version
  • Thread starter Thread starter masteries
  • Replies Replies 44
  • Views Views 5196
Any chance to have also a 'case' ?
(Marked as sold/completed by masteries)
Thanks for your support and interest!
There is a 3D case designed by Javier Rivera,
the link is sent along the tracking number message
However, I have no 3D printer; really I have no enough room space for it :(
You have a message with the details,
Your unit is shipped,
You have a message with tracking number and some information,
Thanks!
Hi
is it the same as this one : https://ko-fi.com/s/8c2b183fb8 ?
Thanks
Greetings,
Its the same device, Fujinet for Apple II;
the functionalities are the same: SmartPort hard disk capable,
disk ][ capable, Wi-Fi functions and CP/M operating system
support with Z80 emulation at Fujinet processor
but build with components that can be managed by our hands,
instead of TSSOP and smaller sized ones.
Due to it is manufactured and soldered manually.
Also, this version is compatible with current v1.4 firmware
and previous firmware versions (in case you have a YellowStone card,
only some previous firmwares are compatible with YellowStone add on card).
You have a message with tracking number and a short tutorial,
the tutorial also contains links for downloable hard disk images
with plenty of contents
can you explain if it's possible to run IIGS dedicated games like Defender of the Crown or just old Apple II software.
Asked to Fujinet developers,
Answer: it can load IIGS specific software when these are presented in .PO or .2mg disk images; basically, if the IIGS software is presented in a ProDOS volume, it will load fine.
There is a video loading GS system 6.04 disk images,
from minute 8:40 to minute 9:38:
Return from holidays!
Manufacturing is restarted,
there are available units!
Hi.
I could be interested by one unit for my Apple IIGS, pending these questions:
- the design of the board seems angled upward and it may block the nearby slots. Why is it not flat behind the smartport?
- i have read that real floppy drives can still be used and connected after the Fujinet, but i don't see how.
- is there a 3D printed case model available to nicely match the GS case instead of the naked board and how does it look like?
- is it possible to have the device instead in a case connected to the smartport iva a cable?
