It is next gen hard drive and oh look......no wiring !
- Graphics
- Integrated AMD Radeon™ Vega Series Graphics in Ryzen Series APU*
- DirectX 12, Pixel Shader 5.0
- Shared memory default 2GB. Max Shared memory supports up to 16GB.**
- Dual graphics output: Support HDMI and DisplayPort 1.2 by independent display controllers
- Supports HDMI 2.0 with max. resolution up to 4K x 2K (4096x2160) @ 60Hz
- Supports DisplayPort 1.2 with max. resolution up to 4K x 2K (4096x2160) @ 60Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI 2.0 Ports (Compliant HDMI 2.0 monitor is required)
- Supports HDCP 1.4 with HDMI 2.0 and DisplayPort 1.2 Ports
- Supports 4K Ultra HD (UHD) playback with HDMI 2.0 and DisplayPort 1.2 Ports
*Actual support may vary by CPU
**The Max shared memory 16GB requires 32GB system memory installed.
I see no problem with that. I always try to optimize the BIOS/UEFI and with a AMD 5xxxG APU/CPU you should take the chance and give the APU more (V)RAM.Do you also have these options in your BIOS/UEFI? Yes but I dont want messing about BIOS because I did made bugged my old computer up called UDOO Bolt over CMOS Stuffs and someone told me that I can Reset it to get back to normal (working computer).
So, how went thing in case of "mini pc" ??thanks for links as DeskMeet X300 seem interesting one
