Found Garlic 68000 CPU Switcher
  • Thread starter Thread starter Timtheloon
  • Replies Replies 14
  • Views Views 684
Timtheloon
retrofanatics.co.uk
Staff member
Staff Moderator
Donator
England
Hampshire
Hello Retrousers,
Im looking for one of these Garlic 68000 CPU switchers
here is a Link https://www.pcbway.com/project/share/Garlic_CPU_switcher_b76db560.html
Anyone got one spare ore making them?
Edit: Thanks @AmigaDigital for sorting this out for me and also looking further than my link for a new version of it 👍 👍 👍
Edit: @Vaderqrt if you have no soldering skills you may have to ask him if he can solder the 68K CPU in to but you may have to supply one to him
I desperately wanted 2, but seems impossible to get it, I went into the pcbway website and wtfff👀don’t understand nothing
Just an update hopefully @AmigaDigital has sorted me 1 out, I'll let you know when it arrives, he may produce a batch of them if it works for me.
i have a few pcb's left , but i read on a1k.org that the 68000 cpu must soldeer right on the pcb , because the keyboard don't fit , but let me know when you get the package
I'll let you know when it arrives maybe using a right angle re-locator first will work with it
I reached out to Amigadigital if he could make one for me, so I believe he has just made one up for me, the switch and cable I will sort out after
When it arrives I will update here everything about it
@Vaderqrt this works like a charm, I soldered a Rugged old 68K CPU in, the 68K had a lots of bent pins so I was happy to straighten the pins the best I could and solder it
Jumper off = TF536 on
Jumper on = 68000 on
Obviously shutting down the Amiga before switching over CPU's
Just got to sort out a suitable switch and add a rom switcher to switch from Kickstart 1.3 for the 68000 and Kickstart 3.2.2 for the TF536.
I am using a right angle CPU relocator for the TF536 to ensure its as far away as possible from the Keyboard
I've added pictures I am using a CDTV version of the TF536 which will but it in a different position than a normal TF536 i just haven't got around to ungrading the firmware or the normal TF536 I have to a CDTV firmware to work with my A570
Fantastic news, I just need two of those for my projects
Nice adapter i didn't know of!
I am curious to see how it will prove reliable when there is some sandwiching with relocator, riser and turbo card. I got a lot of troubles before with too much parts stacked.
Well @AmigaDigital is the guy who sorted me out if you have a wanted thread for one maybe quote him there and send him a PM for his price to make one @Vaderqrt
@Xanxi dont know how I forgot to post this picture
