For Sale Gotek adapter cable Amiga DB23 Oled encoder buzzer rotary + USB KEY
  • Thread starter Thread starter axel81
  • Replies Replies 2
  • Views Views 183
axel81
Italia
Monza Brianza
AMIGA GOTEK CABLE DELUXE / AMIGA GOTEK PACK
I made this new cable adapter version in order to connect your GOTEK to your Amiga Disk Drive Port.(The jumper on your Gotek Drive has to be set to S1)
The adapter cable has a detachable long cable allowing you to place your Gotek drive next to your computer instead of on top of it, therefore no risk of scratching your Amiga case.
With a GENUINE/UNCUT DB23M connector you do not have to remove any screws, cut anything or risk accidental, improper connection which might result in damaging of your Amiga. It is a simple PLUG & PLAY just like in the good old times - genuine/uncut DB23M connector makes it that easy.
ALL GOTEK UNIT HAVE THE LATEST FIRMWARE V3.44!
OPTION AVAILABLE (what you will receive)
AMIGA GOTEK CABLE DELUXE (PRICE 39€)
  • Gotek External Cable Adapter
  • Genuine/Uncut DB23M connector with its original DB23 cover shell and ancorage!No 3D printed casing!
  • 40cm long detachable cable
GOTEK BASE (3digit + push button) (PRICE 49€)
  • Gotek External Floppy disk emulator equipped with 3digit 7 segment display + push buttons + power led. Gotek cable DELUXE is NOT inclueded!
GOTEK DELUXE (OLED + push button) (PRICE 59€)
  • Gotek External Floppy disk emulator equipped with OLED 0.91" + push buttons + power led. Gotek cable DELUXE is NOT inclueded!
GOTEK PREMIUM (OLED + Encoder + Buzzer) (PRICE 69€)
  • Gotek External Floppy disk emulator equipped with OLED 0.91" + Rotary Encoder + power led. Gotek cable DELUXE is NOT inclueded!
GOTEK BASE PACK (Gotek 3digit + cable deluxe) (PRICE 88€)
  • Gotek cable DELUXE inclueded!
GOTEK DELUXE (OLED + push button) (PRICE 98€)
GOTEK PREMIUM (OLED + Encoder + Buzzer) (PRICE 108€)
AMIGA MEGA GAMES KEY (over 1200 games!) (PRICE 19€)
  • 16GB/32GB USB memory contains more than 1200 .adf file games in order to enjoy (Zool,Sensible Soccer,Superfrog,Turrican 1,Mortal Kombat 1 , Project-X....and many others!)
  • Please remember that some gmes require fast ram/expanded memory or different Kickstart version
PLEASE REMEMBER THAT:
  • The jumper for the Gotek Drive has to be set to S1 (external use)
  • Not all Amiga games boot from DF1!
  • Amiga with Kickstart 1.3 needs a boot drive selector adapter to be able to boot from an external drive. I have this selector available here --> https://www.ebay.it/itm/396984059989
  • All GOTEK drives / cable adapter are tested before despatch on my A500 / A600 / A1200
  • GOTEK is fully compatiable with A500, A600, A1200 , A2000,A3000 , A4000 and other retro computers and devices.
  • GOTEK COLOR WILL BE BLACK or WHITE (based on availability)
@axel81 You can't sell the USB stick with installed software unless you include all of the original installation media.
