For Sale Gotek Floppy Drive External ROUND cables
  • Thread starter Thread starter a.mi.goun
  • Replies Replies 772
  • Views Views 121951
Hi
Can I connect a amiga disk drive to the cable?
I am towering my a600, using a atx psu, so I do not need power outlet from the cable.
Leif
Hi Leif, this cable is for connecting Goteks as an external drive. I also have different cable for connecting PC floppy as external drive.
But if you need to connect amiga disk drive as an internal drive you just need standard floppy cable (direct/without a twist).
Hi
I have a micro gotech with female connector direct connectet to the amiga MB.
The only way to connect a disk drive is to use the external port.
I have a amiga disk drive with face plate, so I thourght that this cable, could be a good solution.
Leif
Oh yes, understand. So this cable will not do, because real floppy drives connected to external floppy port require additional motor on signal generation by IC circuit. I also have similar cable to these that works PC-compatible floppy drives (but that one is more expensive one).
  1. VoltureX
  2. nbla000
  3. bdb
  4. dingebre
  5. jakobwesthoff
  6. mortenkjerulff
  7. mnemo
  8. miggymad
  9. RandomInexperiencedGuy
  10. ChrisHammond
  11. utukku
  12. fireful0
  13. hlide
  14. jdryyz
  15. hlide
  16. Negan
  17. rafael138
  18. Hallu
  19. DarkN3m0
  20. kneusarius
  21. tihopop
  22. cloverskull
  23. bdb
  24. slugman
  25. paolopal
  26. rayan259
  27. kosmik
  28. nanus
  29. Dale423
  30. morten.dynamite
  31. l3fthand
  32. MikeUK
  33. abelloni
  34. C16Oli
  35. Luffe
  36. tops4u
  37. Nibitor
  38. leviathan
  39. blodo73
  40. Perseid
  41. deixi1Mu
  42. nizce
  43. ChrisHammond
  44. utukku
  45. steeve2373
  46. bionoid
  47. intipacha
  48. mipko
  49. TomsProjects
  50. utukku
  51. Haybags4000
  52. Freddy
  53. Cryton2707
  54. screemo
  55. doncheffo
  56. plaw123
  57. Hiddenevil
