For Sale Gotek Floppy Drive External ROUND cables
  • Thread starter Thread starter a.mi.goun
  • Replies Replies 772
  • Views Views 121959
A well packaged parcel arrived, thank you very much.
Cable: Works as expected.
DF0/DF1 switch: Not having much luck:
Switch position "A": Real floppy on internal connector acts as DF0. External Gotek not recognised (no 'click' on ejected disk either).
Switch position "B": Real floppy on internal connector acts as DF1. External Gotek recognised as DF2. There is an extra icon on the desktop DF0:NDOS.
User error? I had no idea how to orient the switch into the socket so used the time tested method of aligning the notch on the adapter to the notch on the CIA and then the socket. I have a A3000D, so U300.
thanks,
RDP
On A3000 check to jumper switch J351 if set to 2-3 (single internal drive). See the jumer S0/S1 on Gotek try changing if needed. Adapter must align notch to notch same as CIA.
Thanks for the ideas, I tried many combinations, and the only single time I could get the external cable Gotek to show up as DF1 was when I set the jumper to MO (not S0 or S1). But then DF0 (real internal floppy) shows up as DF0: ???? and cannot be accessed.
Strange.
The 3000D is such a pain to work on.....
Put CIA back to original configuration:
DF0: is internal drive
DF1: does not exist
DF2: is the Gotek, when it is set to S0.
Strange thing is, I cannot sense any difference in moving J351 at all. What should change by moving the jumper (from 1-2, to 2-3, etc.)?
Robert
I expect Gotek (jumpered to S0) to appear as DF1: connected by ext cable when A3000 is set to single internal drive, so J351 does not seem to work as expected. The internal drive is the original drive or modded pc drive? Anyway, I could do my own test, but as my access to A3000D is currently indirect it will take few days.
The drive is a Chinon FZ-357A, so I understand that to be a "real" Amiga HD FDD.
thanks!
RDP
DF0/DF1 switch: Not having much luck...
I have found a solution to your problem. In fact I completly forgot that at bigbox amigas df1 is reserved for internal drives, so it is the bootselector that needs to be modified for df2 instead the df1.
So I need to make you a bootselector for df2 instead. Sorry for inconvenience and confusion, also I will update the first post accordingly.
shipping to uk
shipping to uk
Hi there, I'm considering one of the black or beige cables, couple of question though. I'm planning on using this on both an Amiga 4000 (I notice the discussion on the 3000 re DF1 being reserved, the 4000 is the same) Would this cable work ok on the 4000 and secondly how much is shipping to the uk? Thank you!
Hi, cables work well on every amiga, the above discussion only concerned how the bootselector worked (which also has been solved).
Shipping costs I will PM you.
  1. VoltureX
  2. nbla000
  3. bdb
  4. dingebre
  5. jakobwesthoff
  6. mortenkjerulff
  7. mnemo
  8. miggymad
  9. RandomInexperiencedGuy
  10. ChrisHammond
  11. utukku
  12. fireful0
  13. hlide
  14. jdryyz
  15. hlide
  16. Negan
  17. rafael138
  18. Hallu
  19. DarkN3m0
  20. kneusarius
  21. tihopop
  22. cloverskull
  23. bdb
  24. slugman
  25. paolopal
  26. rayan259
  27. kosmik
  28. nanus
  29. Dale423
  30. morten.dynamite
  31. l3fthand
  32. MikeUK
  33. abelloni
  34. C16Oli
  35. Luffe
  36. tops4u
  37. Nibitor
  38. leviathan
  39. blodo73
  40. Perseid
  41. deixi1Mu
  42. nizce
  43. ChrisHammond
  44. utukku
  45. steeve2373
  46. bionoid
  47. intipacha
  48. mipko
  49. TomsProjects
  50. utukku
  51. Haybags4000
  52. Freddy
  53. Cryton2707
  54. screemo
  55. doncheffo
  56. plaw123
  57. Hiddenevil
