For Sale Gotek Floppy Drive External ROUND cables
  • Thread starter Thread starter a.mi.goun
  • Replies Replies 772
  • Views Views 121935
Hi.
Can that cable be used with a real floppy drive instead of Gotek?
In that case, what would be the setting of the drive (DS0? DS1?)?
If it works that way, i would be interested in one.
Thanks A.mi.goun.
I am interested in the double cable and the bootselector for my Amiga 500. Can the cable really power two external drives at the same time? Mechanical drive and Gotek drive. Is it powered by Disk Drive only?
Thanks for help.
Cables are only for Goteks, not mechanical drives. Dual cable can power 2 Gotek drives easily.
Ah ok great, so I could use the internal mechanical and two goteks externally. Hmm how I know from which Gotek the Amiga will boot? Because the boot selector will only switch between internal or external drive.
That would work well, Amiga will then boot from the first external drive - DF1.
Declaring interest in 1x Light-beige cable standard size. Pm sent.
(Marked as sold/completed by a.mi.goun)
Black single please
Payment done !
Nice end of this year everyone
Package received, nice work, thank you
Declaring interest in gotek external cable, indivison ECS cable, A600 mouse/joystick adapter, 68030 heatsink and a custom cable
Interested in 2x light beige 50cm cables.
Hello, since most of the boot selectors for A500 switch df0 <-> df1 is it possible to make a Dual External Cable with one end connecting to a Gotek drive (df1) and the other end having a female connector for connection of a traditional external floppy drive (df2)? What would be the cost for such a cable?
Edit: Forgot to write that the connection to the Amiga will be with a 23pin connector.
So you want to have at the same time - DF0 (internal Gotek or regular FDD) and external DF1 (Gotek) + DF2 (external regular FDD?
Forgot to write that the connection to the Amiga will be a 23pin connector.
Yes, exactly.
It does,but I want to keep it in it's original condition. Also my boot selector is a df0<->df1 type and I have installed both the Amiga and the drives inside a selve so removing the cables each time I switch drives is very frustrating. That's why I need to have the gotek as df1 and the floppy as df2. The only solution that I can think of is to have a dual cable with bot a gotek connection and a female 23 pin connecor acting as a pass-through.
Ok understand. I think I can make the the cable and hardwire gotek for df1 and the drive for df2.
I still work on the previous requests but when done I will contact you with details.
Clear (light gray)
  1. VoltureX
  2. nbla000
  3. bdb
  4. dingebre
  5. jakobwesthoff
  6. mortenkjerulff
  7. mnemo
  8. miggymad
  9. RandomInexperiencedGuy
  10. ChrisHammond
  11. utukku
  12. fireful0
  13. hlide
  14. jdryyz
  15. hlide
  16. Negan
  17. rafael138
  18. Hallu
  19. DarkN3m0
  20. kneusarius
  21. tihopop
  22. cloverskull
  23. bdb
  24. slugman
  25. paolopal
  26. rayan259
  27. kosmik
  28. nanus
  29. Dale423
  30. morten.dynamite
  31. l3fthand
  32. MikeUK
  33. abelloni
  34. C16Oli
  35. Luffe
  36. tops4u
  37. Nibitor
  38. leviathan
  39. blodo73
  40. Perseid
  41. deixi1Mu
  42. nizce
  43. ChrisHammond
  44. utukku
  45. steeve2373
  46. bionoid
  47. intipacha
  48. mipko
  49. TomsProjects
  50. utukku
  51. Haybags4000
  52. Freddy
  53. Cryton2707
  54. screemo
  55. doncheffo
  56. plaw123
  57. Hiddenevil
