For Sale GottaGoFaZt3R, Pistorm600, Gotek adapter, RTC m.m
RetroFletch
Rating - 97.7%
42   1   0
Sweden
therightside
2025-09-09 : Bumped and updated stock numbers.
These items have been built by myself and are fully tested before shipping.
GottaGoFaZt3r - 256mb fastram for A4000 / 3000 / - €129 / $139 ( 2pcs available )
A1200 8mb fastram + RTC - white edge connector - €59 / $65( 2pcs available )
A1200 RTC module - red - includes battery - €17 / $18 ( 1pcs available )
Pistorm600 for A600 - Purple - includes screws and spacers - GOOD socket - €64 / $68 ( 1pcs available )
Pistorm600 for A600 - Black- includes screws and spacers - GOOD socket - €64 / $68 ( 1pcs available )
Pistorm32 for A1200 White with black edge connector - €75 / $79 ( 2pcs available )
A500 Sideslot to Zorro adapter - Use Zorro cards on A500 - €45 / $49 ( 3pcs available )
A500 Sideslot to clockport adapter - Use clockport expansions* on A500 - €29 / $30 ( 1pcs available )
*A1200 RTC modules does not work, but A314cp and other things do. it mounts fully inside case.
External Floppy ( GOTEK ) adapter - Includes power and data cables - €28 / $29 ( 2pcs available )
Atari ST RGBto HDMI + Audio out & resolution switch - €35 / $38 (1 pcs available )
Apple II VGA adapter with PicoPAL - €66 / $69 ( 3pcs available ) ( also available with cable )
The number of available is how many i have ready to ship right now, i can build more but then there will be a few days longer wait.
Tracked shipping inside EU should be about €15
Tracked shipping outside EU should be about $11
Payment can be made by IBAN transfer or by Paypal in USD or EUR.
All items will be sent as Sale of goods with correct value unless you specify otherwise.
Also check out the following threads for more C64 / Amiga related stuff:
Pistorm32, Pistorm2K, A314CP, RGBtoHDMI, Gottagofastram2000
RIPPLE IDE, RGB2VGA Ultimate, PSX2AMIGA
Pi1541, SD2IEC, TapeCart, Joystick adapters
All these projects are open source and you can find more information about them here :
And also just noticed. GottaGoFaZt3r does not work on the 2000. It’s Zorro 3 only.
Is the "A1200 RTC module - red" still available? Can you please confirm its dimensions? I'm after one compatible with the Solas board, and this one seems to fit the length.
