Guru Meditation in every cold reboot
  • Thread starter Thread starter Templar
  • Replies Replies 24
  • Views Views 4631
Can you be more specific my friend? That sounds a very good start. :thumbsup:
Also, can you tell me how I can run the original 40.68 ROMs? Possibly with BlitzKick?
How I set up the terminator on the on-board SCSI module then?
You have to put in the ROM IC´s from an A4000D. You can´t run Blizkick without a cold start getting the Guru Mediation.
At the top of the I/O-Module there is a 50pin SCSI connector. Please connect your SCSI cable there and see if this helps.
I can´t try it by myself because my A4000T mainboards are searching for a tower case... ;)
Hmm... actually I tried with a set of 40.68 ROMs, without any luck. It refused completely to boot. :(
So you say that just connect the SCSI cable there, without connecting the other end elsewhere?
@Phantom
nobodyii's suggesting to link the onboard SCSI header with the header on the backplate SCSI module to take advantage of the bus termination the module provides.
(good call there's the 'ii' at the end of his alias or that sentence would read really weird :-P).
That way if the SCSI chip and/or firmware expects to see a terminated bus, it will.
I have a suitable cable here to provide termination directly (without connecting to the SCSI module) as a 2nd way of testing nobodyii's suggestion.
EDIT: Then I will kick your @$$ in Kick Off 2. Or the other way round :whistle:
As for the -0.5 MB RAM, the same happens with my CS PPC too, f/w 44.67, no MapROM or anything peculiar in the early menu settings.
So I see three possibilities:
1. OS 3.9 rekicking. But it doesn't happen with my A1200 + Blizzard 1230 IV, full 128 meg shows there. Unlikely, therefore.
2. CS PPC "internal use". The CS PPC reserves for itself a 512 KB block of RAM for whatever use. This seems strange though as the same RAM could be reserved, if needed, in an OS-specific method. Unlikely, therefore.
3. 68040/68060 libraries. So, I checked my Blizzard 1260 + 3.1 OS installation and 0.5 MB is missing there too.
So I suppose the 0.5 MB is "lost" when the 68060 library is initialised.
All right then. I'll be waiting for your special cable to arrive.
EDIT: About Kick Off 2. LET ME LAUGH MATE... :lol:
