Thanks a lot for the link. I installed the other fixes on my 2630 board - resistor deletes. It did not change the situation dramatically.
The most stable (did not hang so far, installed WB3.9, more testing needed) configuration that I have now is:
- A2630 with 2MB, A2091 in leftmost slot, COLSP 4MB board, real HDD
Adding extra 2MB to 2630 slightly increases the chance of hang - things work most of the time.
Using scsi2sd makes the hang very likely.
Hardframe controller hangs generally regardless of the configuration.
I plan to stick to my config and play a bit with my Amiga.
Does it make sense to add bigram to A2630?
Thanks again
Pawel
Thanks again
Pawel
