GVP T-Rex in A4000T
  • Thread starter Thread starter Hivernaal
  • Replies Replies 13
  • Views Views 449
Hivernaal
france
Normandie
Hello,
Does anyone can tell me how to configure a GVP T-Rex (Rev 4) in an A4000T ?
I tried different jumpers settings (int/ext etc...) and :
JP4: - STARTUP MODE... ON = Motherboard CPU present (ie A3000), OFF = No motherboard CPU present.
JP6: - 4040 BOARD ENABLE... ON = Disabled (use motherboard CPU), OFF = Use CPU on 4040 board.
etc... But no way i can't success to nothing...
Any help is welcome
Thank you
LP
Can someone help me a bit ? I tried a lot of different jumpers configuration and nothing happens..
Sorry, forgot about the jumper descriptions! I will pm you later...
Hi on my 4000D there is 2 jumper j100 internal and external to run the gvp TREX both jumpers should be internal or it will not boot
hope this help
Thank you, i tried both INT and EXT...
perhaps there is something to do with the 'burst mode' jumpers ? I will test tonight.
And here is the description of the Jumpers...
JP1: - RESERVED... Default = Off (no jumper fitted)
JP2: - RESERVED... Default = Off (no jumper fitted)
JP3: - RESERVED... Default = Off (no jumper fitted)
JP5: - RESERVED... Default = Off (no jumper fitted)
JP7: - BURST MODE... ON = Enabled.
JP8: - RESERVED... Default = Off (no jumper fitted)
JR1: - BURST WRITES... Default = ON (jumper fitted)
JR2: - BURST READS... Default = ON (jumper fitted)
JR3: - SIMM SIZE... ON = 16MB SIMMs, OFF = 4MB SIMMs.
JR4: - RESERVED... Default = Off (no jumper fitted)
JR5: - RESERVED... Default = Off (no jumper fitted)
JR6: - RESERVED... Default = Pins 2 & 3 connected.
CN6: - FAN POWER, 5VDC power connector for CPU fan.
JR1=on
JR2=on
JR3=on
Just thank you !
It's finally works.
But it take a very long time to boot and needs a reset to boot properly.
A lot of freeze to so I put off the 'burst cache' jumpers (still 30 mips in sysinfo) and now it's OK.
Still need a hard reset to boot but now it's ok (perhaps a wrong 040.lib version...) i have to test...
:thumbsup:
nice to read! I hope you can fix the little lasting problem, too.
---------- Post added at 14:54 ---------- Previous post was at 14:54 ----------
By the way, how much RAM do you have?
