Closed Hardware-Project WIP Amiga 500: 68030 @50, 64MB, IDE, 2MB Chip, Delfina, Flashrom, RGB2HDMI, ...
  • Thread starter Thread starter McTrinsic
  • Replies Replies 8
  • Views Views 1144
McTrinsic
Germany
Leverkusen
Hello all,
I'm selling my "project" Amiga 500 after all.
The components were all meant as a replacement for another computer. E.g. the turbo card to test, if the problem is with the other computer (a Phoenixboard) or with the TC. By exchanging the TC, this was then easy to solve (always the Phoenix). Sometimes the hardware was also purchased as an option to upgrade. Also the example TC.
In the end I had the idea to equip an extra computer with all the extra stuff. However, I thought that would be too much work if something didn't work as planned. When I procured the last component, I already told the seller that the computer might go on sale. It was an A500 from an A1k hardware guru. And lo and behold, the Amiga does not close - which was maybe to be expected with all the expansions in it. ?. Since I do not have time to take care of it, there's a good opportunity for you. I am confident that all components can be made to fit, if for example you take the time to handselect and resolder special sockets and pins. Or have someone help you do it. Maybe someone from Aminet ....
Note: please be aware of the patches available for KickROMs so that the Amiga will always start in PAL. Which can conveniently be loaded with the ROMulator ??
What's in?
  • A500 MB Rev. 5 - was tested prior to be sent to me
  • Original Floppy Disk Drive
  • NO Power Supply
  • "Matze Turbo" with 68030 and 68882 @ 50 MHz, 64MB RAM, IDE
  • 68000 CPU
  • ACE2b for 2MB ChipRAM
  • ROMulator Flash-ROM Replacement from Amiga on the Lake
  • USB keyboard adaptor from electronica4u
  • RGB2HDMI / Denise-Adapter WITHOUT Raspberry Pi
    Jumpered for use with Denise.You need to switch the jumper if you exchange Denise with a Super Denise.
  • Case as seen on fotos, QWERTZ keyboard.
    All case screws, metal shielding etc. are there.
Note: If you plan on using a CF drive, you might want to place the CF2IDE adaptor via IDE cable towards the trapdoor.
That way you will be able to quickly reach the
Other
  • External Floppy Disk Drive - Case with HxC
  • CPU Relocator
  • HID2AMI for USB-Mice (from Aminet)
  • Matze Zorro-Expander for the Expansion-slot
  • Original Agnus (can add if you want)
  • Original KickROM (can add if you want)
  • Original Memory expansion from "back then", see post below
IMPORTANT:
Please check positions / orientation of all components before turning on!
I was putting this together to the best of my knowledge but once the package has left my house its yours.
Since I can not control what you will do with all the stuff, I take no guarantee. It's a private sale, it's all retro.
You need a mass storage. The Matze Turbo provides an IDE.
Please provide your own mass storage, e.g. IDE2CF & CF or IDE HDD.
Asking for Easter Update: 575 650 725 925 950 1000 Euros.
No splits here. I would love to see this system come to life with these components as it would make a great Amiga.
Also for sale elsewhere.
PERFECT for WHDLoad and MP3.
Please understand that a lot of these items come from A1k.
I would like to reserve the right to sell this to an a1k member, therefore, potentially bypassing the "first in line" rule.
PayPal only. I can do this via PayPal Friends.
However, I would prefer to have this managed via regular PayPal with the fees covered by the buyer.
POSTAGE has gone up significantly with DHL.
I only use DHL. Expect this to be easily more than 20€. Not to mention any express rates would you want it :D.
Actual shipping costs will be calculated once I know where this is going and if you need insurance, etc.
I'd prefer to ship with insurance, but if you are relaxed about this package its your choice :).
Sold elsewhere, kept here for reference:
- Delfina Soundcard @ Clockport for e.g. MP3
Please make sure to understand how this connects to the provided clockport-module.
  • "Garlic" Modul to switch between 68000 / Matze Turbo (Amiga must be switched off)
  • Matze Clockport-Expander for the Expansion-port
  • KickFlash ROM-Modul (see https://www.amigawiki.org/doku.php?i...kickflash_a500)
    Unprogrammed, initially needs an original KickROM, will work under Kick / WB 1.3 +
Click image for larger version  Name:	IMG_0821.JPG Views:	106 Size:	136.5 KB ID:	2416252
after some questions I decided to put the optional parts also in. Were the Agnus, KickROM and the ROMulator.
Also adjusted the price.
Have fun,
McT
OK final adjustment, also putting up on sale elsewhere.
I lowered the price to 925 and added an original Memory expansion from back then, see pics. :)
Can be disabled via switch.
Since i have to move the carton in the basement every once in a while I seem to have lost the clockport cable.
If thats an issue for you I can go down another 5€.
Click image for larger version  Name:	IMG_0799.JPG Views:	0 Size:	121.1 KB ID:	2422355
Click image for larger version  Name:	IMG_0800.JPG Views:	0 Size:	128.2 KB ID:	2422356
Click image for larger version  Name:	IMG_0796.JPG Views:	0 Size:	161.8 KB ID:	2422357
