Hi Chaps,
I know, I've been rather anonymous for a while & now I pop up asking for help.
So here it is - I have a project in mind that may be of interest to modders of retro computers in general but I've hit a snag:
Some chips I require are manufactured in the US by Sprintek.
The Good:
I have to say they've been very helpful and will happily supply in small numbers.
The Bad:
Postage within the US seems to be $0.00, but to the UK it's about £55.00 for three chips!
Three Low profile QFN 56 pin packages: 8x8mm - I assume they intend to lay on a private jet and armed guards!
At these prices the project is dead in the water, I'll never be able to make boards cheap enough for others to afford.
So, my request is to any US members - I'd happily send the money up front if anyone feels they could arrange MUCH more reasonable postage to the UK.
Thank you.
Didn't I mention what the project is? Ok:
Some peeps may be aware of interfaces like the >I-PAC<. A way of interfacing arcade gaming pads, etc to an x86 motherboard...
...to help turn your MAME-PC into a proper home-gaming cabinet.
Now, that's all well and good but what if like me you're a bit of a case-modder?
The hardest (most tediously frustrating) part is getting a retro-keyboard to interface with your 'modern' USB/PS2 equipped motherboard...
...The 'standard' method is to gut a PC keyboard like >this< one, then work out how it's matrix is arranged, then work out the matrix for your retro-keyboard, then see if they match.
Usually you end up completely re-wiring said retro-keyboard to match, then the interface chip from said 'new' keyboard can be hacked in and hurrah! You have a working retro-keyboard that will interface with your USB/PS2 equipped system.
Every time I do this I promise myself that I'll never do it again. Surely there must be a better way?
Well, what would be nice is there was a programmable keyboard interface in the same vein as the I-PAC. You could just plug your retro-keyboard into that, program the interface to suit, and Bob's your significant other.
I've only ever found one, it's too big AND amazingly expensive. No, arcade-type interfaces won't do for this. Yes, there is such an interface for Amiga keyboards but excellent though it is, it's too big and not user-programmable.
So my plan is to make such an interface myself based around one of Sprintek's chips.
-The board will hopefully be less than 3x2cm
-Covered in pin-headers and a USB port
-It will be fully customisable in software
-Will only need a USB-equipped PC to program it
-Will interface via PS2 or USB
-Should be able to handle Row/Column of 8x20
-Can handle a mouse if required
-Could handle digital joypads if required
-Will have LED headers for Caps-Lock etc
-Will cost in the range of £20.00 to make @ home*
*Assuming I can do something about the shipping charges.
So who'd be interested?
The Good:
The Bad:
Thank you.
-Amazingly tedious and fiddly process-
