Tchucolate
Retronaut
Hey, I have a Picollo SD64 that did not come with the custom passthrough cable for the Amiga DB32 out, to its custom DB9 in. I have seen a pinout for both ports, and I have the correct connectors for both ends. I am wondering, does it require ALL 9 pins to be connected on the DB9, as I only have 8 core cable to hand, and would rather not order 9 core (and wait for delivery).
See this guide here It shows 3 grounds, one for R,G and B and also a separate ground for the sync signals, which it appears can be either combined IN as pin 4, or as separate H and V as pins 4 and 5. I'm assuming I NEED that Sync ground as well, and will HAVE to order some 9 core cable.
