cugar124 Well-known member Joined Feb 7, 2011 Posts 1,852 Country England Region Norfolk Oct 1, 2024 #1 Hi Guys, as the title says, has anyone else had problems with the current windozs 11 and cf cards?
miggymad Current HTTP status code: 418 Assistant AmiBayer Joined Aug 1, 2019 Posts 2,696 Country United Kingdom Region Central Oct 1, 2024 #2 Running WinUAE as an Administrator?
cugar124 Well-known member Joined Feb 7, 2011 Posts 1,852 Country England Region Norfolk Oct 1, 2024 #3 Yep that did it, damn strange never had that before. Thanks for a simple fix LOL
fitzsteve Retired Slacker Assistant AmiBayer Joined Aug 19, 2009 Posts 20,777 Country UK Region Sevenoaks Oct 1, 2024 #4 I had the same issue with an SD card on my Win11 laptop, just doesn't show up, sorry I can't offer a solution I just used my Win10 PC instead. Might be worth checking the WinUAE forum over at EAB
fitzsteve Retired Slacker Assistant AmiBayer Joined Aug 19, 2009 Posts 20,777 Country UK Region Sevenoaks Oct 1, 2024 #5 cugar124 said: Yep that did it, damn strange never had that before. Thanks for a simple fix LOL Click to expand... Oh cool that worked for you. Great stuff, didn't help me sadly, might have been because it was the built in SD card slot or something in my case.
miggymad Current HTTP status code: 418 Assistant AmiBayer Joined Aug 1, 2019 Posts 2,696 Country United Kingdom Region Central Oct 1, 2024 #6 Best way of curing this is to ensure WinUAE is always run as Administrator. If you right click on the WinUAE icon and select Properties. Click on the Compatibility tab and check the box "Run this program as an administrator". Click Apply then Ok. Admin rights for WinUAE every time!
