It's a question that concern most people nowadays I believe, so here it is. Currently I have in daily use an A1200 and an A4000, which I would like to use them under one LCD monitor. I tried two KVM switches, but to no avail. All of them (?) they seem to get power from the PS/2 connectors, which of course if you connect two Amigas, it's impossible, as the only cable you connect is the monitor one. I found another KVM switch which uses an external supply of 9V, but again nothing. Is there anyone with a better solution?
