as title
Selling our Jamma Electrocoin arcade cabinet with 619 in 1 PCB,
2 player 6 button + 1 and 2 player start buttons.
We need the space back in the kitchen for a dining table and no where else to place it in the house.
will post more detailed photo's and a video of it working depending on interest
obviously this is pickup only. I could help deliver this locally if you don't have a van or estate car.
the cabinet is original from the 80's and as such has normal use wear for wood of this age from an arcade. has wear around the base and the odd chip near or around the edging.
the cabinet has both sets of keys for cash box and coin mechs, the coin mechs are mechanical and set to 10p size or you can just enable free play.
the coin mech front and control panel metal work has been re-powder coated to a good finish.
the cabinet contains a hantarex 900/e Horizontal arcade monitor in full working order, no burn but does pinch slightly (hour glass effect) its beyond me what to adjust to correct this. Contains original psu & looms, i have a new tube for the marquee but haven't got around to wiring it up or testing if the ballast works.
sent to eBay
Available Elsewhere
there is a new PCB from Australia that comes with a Raspberry PI3 and gives near perfect arcade emulation and true 15khz screen modes.
I was going to get one,, look here.
http://www.aussiearcade.com/showthread.php/67986-JAMMA-board-from-Raspberry-PI
but decided to sell my cab instead.
sent to eBay
Available Elsewhere
