PM replied.Interested in 4 kits, sending PM
I'll check if I can make it Amiga compatible in the next batch. I checked some Amiga motherboard images and they seem to have a more common DB9 connector with the big pins on the side of the signal pins.Have to withdraw interest. Not because of the postal strike, but rather because I figured that it won't fit the Amiga (at least the AGA models). That's because the ESD chips occupy the area where the DB 9 connectors have their soldered large "anchor" pins.
If a redesign could be made, where both ESD chips sit alongside the outer pin row of the connector ( there should be a clearance of about 7 mm to the edge of the Amiga's mainboard that can be used), I would be in again for AT least 8 kits.
Hi again,
I've been using a lot of these, so I'd like to declare interest in another 10 soldered PCBs (5 sets) with postage to the UK.
Many thanks,
Adam
Hi again,
Many thanks,
Adam
PM replied.
Hi again,
Many thanks,
Adam
PM replied.
Payment sent for seven sets (14 PCBs).
Declaring interest in another 10 soldered PCBs (5 sets) with postage to the UK, PM sent.
