Sold KS MASTER - USB Programmable ROM with Auto-Switch/KickSwitch (1MB)
  • Thread starter Thread starter pc13589
  • Replies Replies 128
  • Views Views 14587
Packet received and positive feedback.
Trying to get it running on a A600. Very good support from the seller.
It now actually works. I can program a ROM into it and the Amiga will actually start from it.
Thanks for the support !
For info, installation in an A600
Declaring interested in one.
(Marked as sold/completed by pc13589)
We'll never know what happens if you accidentally plug the rom in the wrong way around ;)
I put a white dot near pin 1 to help with the orientation but it's quite small and it's near the header so I can see how it might get overlooked
A few more roms are coming in a couple of weeks, unfortunately I can only make them in very small batches, soldering small SMD components is quite time consuming...
Kickstart 1Mb works on Amiga 2000. I recommend.
Received payment from abundantmussel
Finally got some more components so I now have 4 more roms available if anybody else is interested
I see pin A18 and A19 on pcb, is there posibility to use 2mb rom ?
Good catch :)
I might eventually make a 2MB version but at the moment I'm using 1MB chips, the board was designed with both options in mind so that's why there's a pin marked A19
That pin is currently used for the external reset line
how much for 2mb version ?
At the moment I don't have one available, for a 2MB version I will also need to make some changes to the firmware so it might take a while
Unless you need to use the full 1MB for a single rom image you can still have 2 separate images, one in the lower 512KB bank and one in the upper 512KB, and switch between them even with the 1MB version
It's not as convenient as having 4 banks but since you can reprogram the rom quickly it's usually not a problem :)
I would like to make custom rom with scsi.device, eide.device and partition contains workbench, filemaster and other useful tools. I saw that it's possible but need 2mb space.
Declaring interest. Is it possible to have one with ehide.device too included to use in a a1200 with terribile fire 1230 64 mb ram ??
(Interest marked as expired by pc13589)
I updated the first post and added a new item, it's a small module to program these roms from an Amiga.
Totally unnecessary and actually slower than programming them from a PC via USB due to the speed of the serial port, but I thought it would be cool to have an alternative to the PC software so here it is :)
  1. nikos.rizos
  2. grosi
  3. Neztik
  4. PRS
  5. dargrz1977
  6. Picard
  7. AwakeningStar
  8. ChrisHammond
  9. dargrz1977
  10. grosi
  11. Isense
  12. highpuff
  13. nicoppc
  14. dayowalker
  15. Wrangler
  16. erique
  17. Reborn
  18. abundantmussel
  19. St233t
  20. McTrinsic
  21. Dindi
  22. bedrock
  23. McTrinsic
  24. bedrock
  25. neocdtv
  26. St233t
  27. botfixer
  28. nicode
  29. fpmpaolo
  30. dargrz1977
  31. polarstar
  32. Leoncjo
  33. neffets22
  34. mr.spiv
  35. veper
  36. gnyx
  37. jym
  38. ElectroBlaster
  39. dargrz1977
  40. PPow
  41. EagleRacing
  42. Czig
  43. atomontage
  44. II-IRON
  45. Thirty-Thirty
  46. Romel
