Making a adapter from din to scart (1084s)
  • Thread starter Thread starter Anders1984
  • Views Views 807
Anders1984
Sverige
Karlstad
Hi guys!
I want to make a din (I belive its 6 pin) to scart Female so I can connect my snes and ps2 to my 1084s.
Can anyone who has made this please help? I have a broken cable with the din contact in one end, so I just have to add the female scart connector to the other end.
/Anders
Hi.
It is doable but is not so simple as direct pin to pin soldering as de DIN connector lacks composite sync input used by the scart, it uses split syncs ( V-sync and H-sync) instead.
So you'll need to make a composite sync striper circuit with the EL1883 IC.
Also you can solder a female scart plug to the 1084S (speaking about the old boxy 1084S model wit DINs and scart pre cut hole )
See here (spanish) :
http://www.retrowiki.es/viewtopic.php?t=200032010
You'll need to relocate an audio cable, solder the female scart plug and close the 9289 bridge like seen there.
Hope it helps.
