pm sendDeclaring interest.
Declaring interest for Mini GBAPII And VGA adapter
Still available 4 or 6 pcsDeclaring interest.
Thanks can I order GBAPII and scandoubler. Please adviseStill available 4 or 6 pcs
Now am on holiday back after 2 weeks
Ok I guess Mini GBAPII And VGA adapter will be fine.Only GBAPII left
No scandoubler
Card received thanksDeclaring interest.
Declaring interest in one mini GBAPII and VGA adapter. Could I check if it includes the metal backplate ?
Did you bought same scandoubler like i done?Hi, just in case did you have some cable for the link between the gbap and the scan doubler?
I brough the gbap but the scan doubler was not available at the time, so i brough one on amiga68k.
The problem is i cant link them with the cable i own (the one for the vga adaptor only), the connector at the end of the cable has more pin and is slimer.
Only video card is availableDeclaring interest.
Is it still available?
Version with scandoubler
Also, is there a longer cable available for the Amiga 2000?Did you bought same scandoubler like i done?
Show photo please
You need adapter ribbon cable is okHi, just in cas did you have some cable for the link between the gbap and the scan doubler? I brough the gbap but the scan doubler was not available so i brough one on amiga68k, the problem is i cant link them with the cable i ownView attachment 2490994
Here you can buyAlso, is there a longer cable available for the Amiga 2000?
Thank youHere you can buy
Pm sendDeclaring interest.
