*nudge* Whilst you're here, would you be prepared to have a go at replacing the Fat Agnus socket on an A2000 mainboard?
Just got mine back to life, usual battery corrosion type stuff. I've got a turned pin socket sat in the CPU socket in that which appears to work for now, same for the ROM socket. Good enough for testing...
But, also the pins in the Agnus socket are rather tarnished.. Sit the IC in a certain way most of the way down, it's OK. Sit it in completely, and it flakes out.
I don't mind having a go at the CPU and ROM socket myself (although if you can do Agnus you might as well do the others if you don't mind) , but I fear I'll knacker things up attempting to desolder the Agnus socket, and I don't want to consign an A2000 mainboard to the scrapheap!
Cheers!
