Closed Modding and repair services
  • Thread starter Thread starter Bad_Ad84
  • Replies Replies 178
  • Views Views 34759
Hi guy
I've joined this site for Xbox related retro goodness, was wondering how much you charge for Ram upgrade to 128meg please? I understand I have to aquire the ram myself.
Also any chance you know how to do mod the box so its a slimmer size? I've been looking for the Super Slim Xbox cases but I think they're long gone now :(
I don't think there was a genuine slim case for the xbox (correct me if i'm wrong) they were custom made by owners by removing the dvd drive and flashing the modchip or tsop with a no dvd bios.
They then cut the case down to a size they were comfortable with and replaced the 3.5" hard drive with a 2.5" I've also heard of some using a pico psu so they could get it even smaller.
My favourite was always this one by ghostavel
So sleek and elegant
I was curious as to what 128Mbyte RAM gets you? I think it breaks some XBOX games (but you can patch the exe on some) and XBMC cannot use the extra 64Mbytes... is it MAMEoX only?
Hi Alexh
Its fine for UnleashX (as far as Im aware) as long as you have the relavent bios. As I only use Coinops now its certainly has added benefits and unlocks more roms than the standard 64mb.
i have a 128mb xbox (bad_ad84 did the upgrade) and i have seen improvement in the N64 emulator (think its called surrealx) before it was barely playable in my opinion now its at least useable. Also coinops, mameX and xbox linux benefit from the added ram.
remember to use mamox 128Plus.
games should not suffer any ill effects. "your thinking of a 1ghz cpu upgrade, which does have a xbe patch"
Most emulators will be able to utilize the extra ram.
Most official games just wont see the extra ram
you have a few bioses that can use the extra ram. i recommend IND bios. You can also use cromwell if you wanted to make a linux box.
XBMC will see and use the extra ram.
but even with the extra ram id still ony use 720p max res.
thats correct.
although you dont need to use a 2.5 drive.. You cut down the case
you take the dvd out and then cut off everything above the line where the bottom of the dvd player would sit. then you cut down the dvd cradle so it fits in the case, the 3.5 inch hdd sits in the dvd cradle, you trim the inner supprts of the top of the case down so it can again slide down fully on the bottom half, the case top will sit flush on the xbox so its level with the feet of the thing. You take the sheilding off the top half of the case, And above where the stock fan is are some more strut things. You trim them off too and then the stock fan will fit in the case..
You can also do it to a softmod by using a PCB from a dvd player. but thats just a silly solution to a simple problem.
Its a prety easy mod to do.
of course some people went crazy changed the psu. removed caps. used ultra thin heat sinks and 2.5 inch drives and custom made cases out of plexi or similar molded plastic.
These can be REALLy thin. But generally a slim box is easy to make as a basic version.
They end up something like this..
scaled.php
i made that oen with the method described above..
i also added a 80MM fan to top center of the case with that dragon cut out fan protector. was a 3 coulour lked fan.
The buyer was prety happy with it.
that pic is when it was Almost finished..
wasnt screwed together or anything then.
That really kool mate. How much would you charge to slim my Xbox down to that size?
not my thread and im not here to advertize my service. and i shut up shop for a month or so due to re wiering.
Yes, those cables would be easy enough to make. However, I would need to know the pin out of what is connected to what.
:) Cool ,
well the cable on the right (without buttons) is for the lcd screen ,
the other one with buttons is to control the text and select , there is an explanation on page 26 of the archive i attached
it seems like this :
Pin 1 should be connected to all the extra buttons, then follow the pinout in page 26(7.3 User interface)
1 - VSS (Common to all push button)
7 - BUTTON_DOWN
9 - BUTTON_UP
8 - BUTTON_SELECT
Hope i'm understandable...i'm noob in electronics sorry.
:)Hello Bad ,
did you had time to have a look ?
Thanks.
PM me tomorrow (as ill be at work and have more time). Been run off my feet this weekend!
Gbs 8220 being sent back tomorrow. Already packed and ready to go
Sent from my iPhone using Tapatalk. Please excuse any crazy auto corrects or lack of detail (links to info sources)
Hxc returned today. Gbs8220 also returned today.
:) hello Bad , just to know , is it possible to let you a feedback when all will be finished ?
Modded GBS 8220 and cable for use with snes received all working fine, thanks, feedback submitted :)
Hi
Do you offer a recap service to replace all caps etc on an Atari STE? If so PM me some details and prices etc?
Thanks
