Hi Guys. Here's my Amiga that I've been working on, and I built the computer using parts that I got off eBay. I was able to get a 500+ board from a guy in the UK. The 2 meg fast ram board (From eBay too)
The IDE adapter is from MLK. The problem was where it fit the CF IDE adapter. You see I wanted full access to it without removing the top cover and the RF shield too, so in the end I decided to fit it under the floppy drive
and I had cut a very neat slot in the bottom case too, (so I can remove the CF card anytime). But I had the replace the IDE headers on both adapters to 90 degree ones, so they would be low profile, and the jumper headers on the CF IDE adapter too had to replaced with wire jumpers, as for the power, I spliced the wires into the floppy cable.
I powered up the board and Oh Nooo, just a bloody grey screen, but it did come on in 30 secs Phew!!. You see I replaced all the caps on the motherboard, so maybe the board was just settling down.. Oh the black cable that goes to the sin 500 board is the external power wire. I have soldered it to a d/c jack with is fitted to the back of my Amiga (just incase I need external power to the memory board).. One more thing. I have fitted a plate to the underneath of the floppy drive, so the IDE cable won't touch the drives spinning wheel or the pcb..
What I'm doing now is cutting a slot in the top case for the CF IDE led, which I have already fitted to the keyboards pcb (The keyboard is the old soldered one)
Take a look at the pics of what I have done to my Amiga..
