May I ask how do you connect it to the Atari ST? Final version has no wires, no soldering needed? Just plug the connector from outside of the Atari ST?
Yes, it is plugged directly to the Atari ST/E hard disk connector. There are no airwires, and soldering is not required.
Its a plug&play device, despite you need to use a micro USB cable and an external power source.
However, there are users using internal Atari ST/E 5 volts to power the device; but in this case, you need to attach wires to 5 Volts and GND pins of the ST/E.
