Chinners
Up for sale is my Nintendo Gamecube Platinum (or silver)
It is a UK PAL console, and has been chipped with a XenoGC, so will play other regions and do other things you would expect.
It also has, neatly bolted onto the underside, a matching silver Gameboy Player, which is working a-ok as long as you have the required boot-disk.
There is an RGB Scart lead, a composite output lead, 2 Power packs (both working), 2x 128mb memory cards (unofficial) and one official silver controller. The rear cover that you remove when installing the Gameboy Player is also here.
Whilst I had it in bits installing the modchip, I changed the LED on top from a boring orange one to a much prettier one that cycles through many colours. Other than these mods, it is original, so no using of 12cm DVDs in it, just the mini 8cm ones.
On the subject of 8cm DVDs, ALSO included are 12 new, shrinkwrapped 8cm TDK Branded DVDs, 10 open DVDs, some with public domain stuff on, and 4 empty cases as spares. The laser has been adjusted to work with these blanks and original disks.
There is the outer box and some internal cardboard packaging that came with it, but I can't fathom out how it all goes together.
Generally this lot is in great condition, however the controller does have a few wear marks where it has been placed down on a surface, and the silver paint has scraped off a bit.
The 16GB SD card is not included, it was put next to the chip when I soldered it in place to give an idea of scale of the mod chip.
Price. Now this is a bit tricky as I have no idea of market value of this exact setup. I would be happy getting £50 for this lot, and £5 basic UK p&p, payable as paypal gift
