well i will always reccomend a 15w pencil iron to any one not overly confident.
30w/40w irons are useable when you have a bit more expiriece. but mostly people tend to burn traces with those when they arent used to soldering..
One of these is perfectly fine.
http://dstretail.co.uk/index.php?main_page=product_info&cPath=322_327&products_id=6660
they are inexpensive and have a nice small tip you can probably find one at a local hardware store for a little bit less than that.
it is possible that you have 5053 bios installed so that would mean i can prep a hard disk for you if you wanted me to do that.
The hard modded board will be fine like that. as a part of sheer luck and ignorance MS managed to put the caps in a reasonably safe place on the boards in the early versions. so the damage generally looks a lot worse than it is. "not safe enough that they didnt move the things to a totaly diferent sopt on a 1.6 and changed the type of cap used)
But it is a definate need to remove the things asap. Where as the area they are in isnt overly critical the damage can spread to near by components. (namely a transistor and a few other smd components) and in extreme cases it can eat through the board entierly.
but usually it just looks worse than it is.
once you neutralize it and clean up the area there should be nothing to worry about.
