@oldman1000: Could you be a bit more precise on this?
Main thing is you should mention your gear. What Amiga do you want to carry this on? Do you also have the external Apple floppy drive?
If you intend to use a PC for the transfer, is it one that does UAE ok?
Solutions could be surprisingly easy some times!
As a matter of fact, you could make your life easier if you have an optical drive with your Amiga setup. You could always burn the OS images onto a CD-RW disc so as not to waste media, and thereby copy the contents to your Workbench. After that, you can either use the special format A-Max utilizes for floppies, or Apple format if you have the external Apple drive.
The link that KenZakreski gave you is the ideal one to download the 4 disk images from.
If you haven't the manual: http://redump.emubase.de/lsd_view.php?id=269
Good luck, and keep us posted!
