BobbinThreadbare
Hi folks,
I haven't been active on here in a while but I'm starting to do a bit of new year cleaning and will have a few things up for sale shortly as I have way too much stuff.
First up is one of my spare VIC 20s. This is a PAL machine, using the shorter cost reduced / CR board that requires a C64 style power supply. It's just the machine itself, no PSU, no modulator, no cables, etc. It's fully working, including all keys (nothing you need to press hard or repeatedly try) and in good if not immaculate condition. It has some light yellowing across the case and 4 of the 6 latching posts at the back of the case are broken, though the case sits closed without issue when screwed together.
Photos attached. Ignore the pinched LED cable next to the joystick port - the case wasn't screwed together when I took the photos and I only just noticed it (doh!). Screenshots are from an LCD connected via composite. It looks a lot better on a CRT, as they all do.
£35 plus postage. You may also collect (from Wokingham, Berkshire).
Edit: Price now £35 excluding postage (was £50 including UK postage, then £45 including UK postage).
