For Sale Parts 68030FE25C, 100-pin zorro slots and more (for e.g. A4000TX)
  • Thread starter Thread starter mkl
  • Replies Replies 51
  • Views Views 8357
mkl
Finland
Helsinki
Some parts available separately:
MC68030FE25C cqfp 10€
DRAM 512Kx8 tsop 2.50€
100 pin slot 2.50€
DS1000G-25 2.50€ (straighten smt bent stub pins and solder from top side)
SIMM socket 2.50€
for A4000T (tower) clone: ssop-48 74FCT16245 1€
chips and sockets 0.50€/piece:
74F32 soic
74F74 soic
74LS125a soic
SN75188 (=DS1488) soic
SN75189a (=DS1489) soic
74HC4066 soic
74ABT244 soic
PLCC20 smd socket
PLCC28 smd socket
Dual minidin-6 socket 1€
a few:
ADV101KP30 3€
28.37516 MHz PAL oscillator 3€
28.363 approx NTSC frequency 1€
KIT:
"Chip" resistor, capacitor, ferrite and arrays(nets) "full" kit for A4000TX (excludes polymer caps and RTC trimmer) plus smd fuses 25€
2x smd fuses 1.85A
Note: a few extra pieces for most "chip" parts:
2x 10uF smd 1206 ceramic
1x 10uF smd 0805 ceramic
1x 1uF smd 0805 ceramic
41x 0.22uF smd 0805 ceramic
60x 0.1uF smd 0805 ceramic
2x 0.047uF smd 0805 ceramic
10x 0.01uF smd 0805 ceramic
2x 6800pF smd 0805 ceramic
2x 3900pF smd 0805 ceramic
4x 330pF smd 0805 ceramic
5x 100pF smd 0805 ceramic
1x 56pF smd 0805 ceramic
2x 27pF smd 0805 ceramic
4x 22pF smd 0805 ceramic
1x 0.047uF smd 1206 cnet-4
11x 1000pF smd 1206 cnet-4
11x 100pF smd 1206 cnet-4
4x 47pF smd 1206 cnet-4
2x 470k smd 0805
2x 100k smd 0805
2x 11k smd 0805
11x 10k smd 0805
5x 4k7 smd 0805
4x 3k3 smd 0805
8x 2k7 smd 0805
2x 2k4 smd 0805
8x 1k2 smd 0805
24x 1k smd 0805
2x 750R smd 0805
2x 680R smd 0805
1x 562R 1% smd 0805
5x 470R smd 0805
3x 220R smd 0805
1x 120R smd 0805
1x 68R smd 0805
37x 47R smd 0805
1x 47R 1W smd 2512
5x 33R smd 0805
2x 22R smd 0805
2x 20R 1W smd 2512
5x 1R smd 0805
1x 1R 1W smd 2512
5x 10k smd 1206 rnet-4
5x 4k7 smd 1206 rnet-4
1x 3k3 smd 1206 rnet-4
17x 2k7 smd 1206 rnet-4
2x 2k2 smd 1206 rnet-4
1x 1k2 smd 1206 rnet-4
34x 1k smd 1206 rnet-4
1x 470R smd 1206 rnet-4
13x 330R smd 1206 rnet-4
1x 75R smd 1206 rnet-4
6x 68R smd 1206 rnet-4
17x 47R smd 1206 rnet-4
10x 33R smd 1206 rnet-4
11x 150R ferrite bead smd 0805
8x 48R 6A ferrite bead smd 1206
4x 150R ferrite bead smd 1206 fbnet-4
Postage starts at 3.05 € 20 grams untracked priority.
SOLD: Almost complete lot, excludes Amiga chipset and CPU connector and CR2032 (holder included).
Price 200€ 16.4.2024 (was 250€)
Two 8 MB SIMMs added.
Comparison: Mouser cart from Hese 277€ + VAT (free ship though)
Plus you get CPU, DRAMs, ADV101KP30 (used), 25MHz FPU(used), 2x 27C160, RTC, sockets for RTC and GALs, PAL and 28.636MHz oscillators, and some extra pieces of most parts in cut tape, which have tags. Also a new in package 1.8m VGA cable.
GALs and mouse PIC preprogrammed.
(bom summary)
-------------------------------[ Summary ]-------------------------------
1x 100uF smd 0805 ceramic (optional) (not included)
5x 100uF smd elco
12x 47uF smd elco
9x 22uF smd elco
1x 10uF smd elco
2x 4.7uF smd elco
2x 470uF th elco
1x 22-47pF trimmer cap (TZB4)
2x 470k smd 0805
2x 100k smd 0805
2x 11k smd 0805
11x 10k smd 0805
5x 4k7 smd 0805
4x 3k3 smd 0805
8x 2k7 smd 0805
2x 2k4 smd 0805
8x 1k2 smd 0805
24x 1k smd 0805
2x 750R smd 0805
2x 680R smd 0805
1x 562R 1% smd 0805
5x 470R smd 0805
3x 220R smd 0805
1x 120R smd 0805
1x 68R smd 0805
37x 47R smd 0805
1x 47R 1W smd 2512
5x 33R smd 0805
2x 22R smd 0805
2x 20R 1W smd 2512
5x 1R smd 0805
1x 1R 1W smd 2512
1x 47uH inductor smd 0805
2x 1.8A polyswitch fuse smd 2920
15x 1N4001 sod-123
5x 1N4148 sot-23
4x 1N5817 sod-123
3x 2N3904 sot-23
1x 2N3906 sot-23
2x 74LVC1G38 sot-23
1x FDN357N sot-23
2x MPF102 sot-23 (or 2N3819 or J113)
2x 74FCT16646 ssop-56
6x 74FCT16245 tssop-48
1x 74FCT16244 tssop-48
1x 74HCT4066 so-14
1x 74HC4066 so-14
3x 74FCT244 so-20
3x 74HCT174 so-16
1x 74HCT166 so-16
2x 74LS125 so-14
1x 74F86 so-14
2x 74F74 so-14
1x 74LS74 so-14
2x 74LS38 so-14
1x 74F32 so-14
1x 74HCT32 so-14
1x 74F08 so-14
1x 74HCT08 so-14
2x 7407 so-14
2x 74F04 so-14
1x NE555 so-08
1x DS1488 so-14
1x DS1489 so-14
1x 7905 d2pak
1x LM833 so-08
1x LM385 so-08
1x LF347 so-14
1x LD11117A sot-223
1x ATMEGA88-20AU tqfp-32
1x PIC16F84 so-18
1x GAL22V10 plcc-20
4x GAL16V8-10 plcc-20
3x GAL16V8-15 plcc-20
2x 27C400
4x 512Kx8 DRAM soj-28
1x DS1000K-25 dil-14 (or EP8700 dil-14 or DS1100Z-25 so-08)
1x RP5C01 dil-18
1x ADV101KP30 plcc-44
1x MC68030 QFP CPU
1x MC68882 PLCC FPU
1x 32.768kHz crystal smd 3215
1x 4MHz crystal smd 10x4.5mm
1x 8MHz crystal smd 3.2x2.5mm
1x 28MHz oscillator dil-14
1x 50MHz oscillator dil-14 (or 50MHz smd 7x5mm)
1x green led smd 1206
1x Alice plcc-84
1x Lisa plcc-84
1x Paula plcc-52
1x Super Buster plcc-84
1x Fat Gary plcc-84
1x Ramsey plcc-84
2x CIA plcc-44
1x Bridgette pqfp-100
1x A3000/A4000 CPU slot connector
1x ATX 20-pin connector (molex 39-29-9202)
1x 6-pin mini DIN dual female
1x 15-pin DSUB female vga
1x 25-pin DSUB dual female-male
1x 9-pin DSUB dual male
1x 3.5mm stereo jack
1x 20x2 pin header
1x 17x2 pin header
1x 12x2 pin header
1x 2x3 pin header
4x 50x2 pin edge connector
3x 31x2 pin edge connector
1x 27x2 pin edge connector
4x 18x2 pin edge connector
2x 40-pin pin strip
1x 4-pin right-angle pin strip
2x 3-pin header molex (fan)
2x 72-pin SIMM socket vertical
2x 42-pin dil socket
1x CR2032 lithium battery holder
Shipping in parcel post:
Zone:
1 19.90€ (e.g. Sweden, Germany)
2 22.90€ (e.g. Italy, UK)
3 & 4: 44.90€ (e.g. Switzerland, Canada)
Finland 7.90€, Åland, Lithuania, Latvia, Estonia 11.90€
Extension pack +20 euros 19.2.2025
0805 parts: 10uF 0.22uF 0.01uF 6800pF(C0G) 3900pF(C0G), 3.3kohm 2k2 562ohm 47ohm 22ohm 1ohm
2512: 1ohm
74HCT166 74LS74 74HCT32 73HCT08 74HCT4066 SN74LVC1G38DBVR(2pcs) NE556 74FCT16245 (two more added, 3 pcs total)
50 MHz oscillator
4 MHz crystal
Dual DB-9 connector
D15(hd) VGA connector
socket for RP5C01
FDN5632N sot-23
1.85A resettable fuse (2 pcs)
Extension pack to stuff below:
Only 1 cheap part lot left
75€ (not including atf16v8c chips)
+shipping e.g 500g Europe 13.75€ priority letter. Parcel post with tracking 20-23 € to some countries.
(Price with atf16v8c chips was 100€ including tracked shipping to Europe, +10€ world)
items added for the last lot:
3 pcs 98-pin 16-bit ISA slots from ebay/taiwan. One piece alternative to 8-bit ISA with separate 62 & 36 pin continuation slots
RTC chip RP5C01 from ebay/china
(NOT included 8 pcs ATF16V8C-5 from mouser (these are not supported by TL866 programmer like the ATF16V8B))
Old Lot price was: 47.50€. With shipping 55/65€. (Value for money)
expanded lot price with shipping to Europe was 60€ (70€ world)
5 new items:
28.37516 MHz PAL oscillator from Aliexpress seller (1 of the lot is tested on A500)
n.o.s. 28.636 MHz NTSC oscillator , less precise than 28.63636
The oscillators don't seem to have enable/disable function on pin 1.
preprogrammed GAL22V10D-15LJ for Romy
Lattice GAL22V10D-15LJ programmed with a4000tx_rev11_assembly Logic U180_ROMY-1MB-GAL22V10-10.jed using Autoelectric MiniPro TL866CS (software 6.85). Programmed parts marked "R" black on black chip bottom.
EDIT: These are -15 parts, while filename suggest faster -10 speed grade. Romy sites on github and elsewhere don't seem to mention any speedgrade requirements.
74LS244 soic. Floppy signal buffer replacement for 74fct244
2 pcs 74ABT244 - believed to be an ok replacement for clock and other driver. both fct and abt logic have cmos inputs with ttl levels and ttl outputs, typical 3.3V high on fct, probably similar on abt.
(MC68030FE25C CPU and 4 DRAMs only - 25/27€ shipped Europe/World)
2 pcs straight SIMM socket AMP (lot price before these 42.50€)
MC68030FE25 cqfp, 25 MHz
4 pcs 512K x 8 dram MCM5L4800AT-70 tsop-28 (just fits to pads on TX)
DS1000G-25 (smd dip-14 version of DS1000-25, short stub pins, socket can't be used. I have straightened the pins for the ic:s in these part kits for dip-14 holes )
4 pcs 100-pin card edge slots AMP (all straight pins, no snap in feature like some models use pins with springy bends. Solder flush to board.)
74FCT16245 TSSOP one piece (of three need) added 30.10.2024
74F32 soic
2 pcs 74F74 soic
2 pcs 74LS125a soic
74HC4066 soic added 3.7.2023
7 pcs PLCC20 smd socket
PLCC28 smd socket (Original lot was 30€.)
36 pin and 54 pin card edge slots for video card. From ebay/taiwan. (price for the two was 10€)
Items below added 30.7.2023 and after
*In needed amount + extra spares of 2-3 pin smd parts in cut tape*
1206 ceramic 10 uF added 30.10.2024
0805 ceramic: 1uF 0.1uF 0.047uF 100pF 22pF
0805 resistor: 100k 10k 4k7 750r 475R(replaces 470R) 68R
1206 resistor net: 10k 4k7 2k2 470R 47R added 30.10.2024: 330R
(yellowish) green led smd 1206
20R 2512 added 10.9.2024
NPN MMBT2222A to replace MMBT3904
PNP PMBT2907A replace MMBT3906
BAV70 common cathode replace MMBD7000HC-7-F double diode (1N4148 single diode's smd)
B0530W-7-F replace sod123 schottky PMEG40T10ERX (1N5817 pth)
2 pcs 42-pin ic socket "dual-wipe"
1x40 breakaway header pin strip straight + 15 pcs tiny jumper blocks
1x4 right angle pin strip
2x12 and 2x3 headers
straight 34-pin and 40-pin boxed (walled, shrouded) headers from ebay/china but with slight quality issue, the pins are rotated a little bit from 90deg angles in the rows if you look close.
extras:
The GAL22V10 was offered at 2€/1, 16bit ISA slots 5€/1
spares for soic's and sockets +0.50€/pce
Other extras moved to other message in thread.
From "NOS" surplus parts lots mostly, like the CPU and DRAM, some from Ebay China sellers, such as pin headers.
Quick shipping due to prepackaged packets.
If you need different mix of parts e.g. for other Amigas, a new offer can be listed for that lot.
Shipping 250 gramms priority 8.25€ Europe (versus "economy" 7.50€) / 19.25€ (10€ economy) World. priority registered mail +16.50€ additional fee (signature, tracking not available to every country)
I have copied Hese's Mouser cart and removed parts i sell, can send it. Cart reduced for the last lot about 150€ (smaller lots at105€+vat.) Also get cpu, dram, rtc, 28MHz oscillators
Declaring interest. PM sent.
(Marked as sold/completed by mkl)
Interested in 1 lot.
Bunp. Some SMD parts added to the lot lately, other parts in July. See first message in thread.
The following notes moved from first post here:
These component values are added to base lot at needed+few spares-quantity e.g. approx 70 pcs y5v 50V for 100nF 0805
Extra quantities
100 pcs 100nF 0805 y5v -20/+80% 1€
100 pcs 100nF 0805 x7r +-10% 2€
1000 pcs 100nF 0805 z5u 4€
5pcs 1uF 0805 -20/+80% 0.50€
100pF 0805 10 pcs 0.50€, 100pcs 1€, 1000 pcs 4€ (I have a lot of these)
22pF 0805 10 pcs 0.50€, 100pcs 2€
47ohm, 2k2, 4k7 and 10k 1206 4x resistor networks 0,50€/10pcs or 2€/100pcs each
10 pcs 4x470ohm array 1206 0,50€
4k7 and 10k 0805 0.50€/10pcs 1€/100pcs
extra substitutes, some odd or barely useful:
(I have made also a fs thread for miscellaneous parts in single and lots quantities in hardware/other)
RTC Ricoh chip from ebay/china, untested, doesn't look bad? I will test the lot when possible. 2€
2 pcs smd plcc44 socket 1€ (not recommended on A4000TX, cia:s are little close to each other so these sockets wont fit)
(Note: I have straight simm sockets for TX now.) Angled simm socket AMP. only one would fit on board ("bank 0"). 2.50€ (older price 3€)
20 pcs rectifier diode smd SMA package 1€ (hyperfast 1A 100V Vf=1.1V) I soldered these to sod123 footprint used - pad is exposed enough at the end for solder to go under
74ls244 soic LS replacement for floppy circuit 74fct245 (other floppy signal drivers are LS)? 1€
SN74AHCT16245DGGR, 3€/pce up to 3 pcs, maybe substitute ide data buffer 5V/8mA drive both directions. Amiga 4000 uses 74hct245:s with similar drive but slower propagation delay. PIO mode hack compatible?
Sold to Cyberstormer SN74ABT16244ADGGR similar to 74fct16244 2€ only 1 piece (sold)
5 pcs 27pF 0603 0.50€. 0603 parts attach to 0805 footprint
5 pcs 56pF 0603 0.50€
5 pcs 33pF 1206 0.50€. Put one to replace the expensive clock adjusting variable capacitor to get some ticking :)
100 pcs 220nF 16V 0603 2€. Rule of thumb is to use rated voltage of 2 times the dc voltage (5V), due to derating of capacitance with voltage on class II capacitors, dielectric like X7R, Y5V, not NP0.
10uF 1210 0.50€/2pcs (to 1206 footprint?)
100 pcs 1Kohm 0603 1€
3 pcs 74f174 soic 1€ (*)
extra 3 pcs 74f125 soic 1€ (**) [2 pcs 74ls125a already included in base lot]
3 pcs 74f244 soic 1€ (***)
extra 74f74 0.50€/ 3 pcs 1€ (****)
28.636 MHz dip-14 (not exactly NTSC 28.6363MHz) 0.50€. Get off-frequency NTSC chipset or overclock 25MHz FPU
49.408 MHz "smd dip-14" "oddball frequency" for cpu. I put proper 50MHz one though. 0.50€
(51.something MHz smd dip-8 0.50 €. Not useful on TX)
0805 Ferrite 40 ohm (vs. 150) 1206 600 ohm (vs. 48) 1€/10pcs.
*If you replace 74hct174 with f174, address lines to cias, rtc and ide will have noisier fast edges and maybe reflections, but I think would work - cf card in ide slot might not get cmos high level, but ttl
**floppy signal driver, same notes as with f174. Also f ttl series faster input speed recommendations
***ttl f244 similar to fct244/fct244t, but maybe not good substitute in all uses in a4000 boards
**** replace 74ls74 in floppy circuit? rising clock edge by resistor not very fast. notes above apply
Advertisement bump
For 47.50€ (+shipping), save over 105€ on bom and get CPU and DRAMs too.
