Hello everyone,
I just received my Cyberstorm MK II 68060 so this card has to go
Phase 5 CyberStorm MK-I 040@40Mhz accelerator with 64MB of RAM (2*32 Mo)
This card to not come with the SCSI Module
Shipping will be 15$for the US with insurance
Asking price is 220$ +15$ shipping
Shipping in Europe is 40$
Paypal payment is a best
I'll copy the driver on a disk:
CyberStorm1_060.dms
install disk v1.0.1
68040.library v40.2, 68060.library v40.305
CyberTools, Barfly
http://amiga.resource.cx/exp/cyberstorm1
CyberStorm1_060.dms
install disk v1.0.1
CyberTools, Barfly
- processor
- 68040 @ 40 MHz (1994)
- modular design
- carrier board
- holds the CPU-, memory-, SCSI- or I/O boards
- two ROM sockets for the motherboard ROMs
- CPU board
- holds the CPU and the optional 2nd level cache
- only this board has to be replaced in order to use an other CPU
- max. clock speed is 80 MHz
- memory board
- four 72 pin SIMM sockets can accept 128 MB RAM
- supports 4, 8, 16, 32 MB SIMMs
- burst RAM access
- mounted vertically on the carrier board
- optional 512 kB 2nd level cache module
- optional Fast SCSI 2 board
- FAS216 controller IC
- transfer speed: 7 MB/s asynchronous, 10 MB/s synchronous
- 50 pin internal header
- MiniDB50 external connector
- active bus termination
- SCSI Direct compatible
- supported by Linux and NetBSD
- optional I/O board
- Fast SCSI 2 with the same specs as above
- 10BaseT Ethernet port, 10 MB/s
- RS232 serial port, 2 MBaud/s
- notes
- may not work with the Retina Z3 graphics board
- cannot map the ROM into fast RAM
