Sold Prelude ZII
Hello! Can you try to record audio at 16bit 44.1Khz with samplitude and see if it's all ok?
Thanks!
Thank you AmigaDigital for a very nice build card that I received around 2 weeks ago. I only have A4000 with 030@25 but if I use uncompressed files I can play back at full CD quality using Play16 and the sound is very good!
Great that it is working great , i know that the mpeg-it module moest run great on the 030 for playing mp3 because the chip make it possible, even it must run also on 7 MHz , the use the same that use for the parallel mas player , so the mpeg-it use hardware to play mp3 and the prelude use software, that means that you need a 040 or 060 cpu to play mp3 on software mode , the mpeg-it use lower cpu like 020 , 030
