AFAIK there is no 7 LED flash error code on any Amiga. You are most probably seeing a software failure (which does flash the LED over 5 times) culminating in a reset and/or a Guru Meditation error displayed on-screen.
Check the on-screen colour sequence when you first switch on the A4000. The colours denote various checks and balances before everything boots up.
The following colours are valid for all versions of AmigaDOS since Kickstart 1.3. However, there were several more colours in 1.3 compared to anything included after Kickstart 2.0 was released. All of the colours listed below are the same for all versions of Amiga kickstart.
- Red - An error in the Kickstart rom as detected.
- Green - An error in the Chip Ram was detected.
- Blue - An error in the custom chip set was detected.
- Yellow - The CPU encountered an error before the system's error-trapping code (the code the calls up the Guru) was in place.
- Black - No CPU detected.
- Grey - CPU Passed the test.
- White - CPU failure.
The following is based on an AGA based A1200/A4000 Amiga. This is different for older OCS based systems.
The system performs the following test sequence:
1. Delays beginning the tests a fraction of a second to allow the hardware to stabilize.
2. Jumps to ROM code in diagnostic card (if found)
3. Disables and clears all DMA and interrupts.
4. Turns on the screen.
5. Checks the general hardware configuration.
If the screen remains a light grey colour and the tests continue, the hardware is OK.
If an error occurs, the system halts.
6. Performs checksum test on ROMs.
If the system fails the ROM test, the screen display turns red and the system halts.
When the Amiga is first switched on the keyboard might blink a number of times to indicate one of the following errors.
- One Blink = ROM Checksum failure
- Two Blinks = RAM test failed
- Three Blinks = Watchdog timer failed
- Four Blinks = A short exists between two row lines or one of the seven special keys (not implemented)
