Re: Q: Amiga PCI Solutions
1) Correct!
2) Incorrect, no way to make a 5V busboard work with 3.3V devices (lack of power supply feed).
2b) Probably not, the driver is written intended for the 3.3V version. Must test to know, although 5V versions are dead slow.
3) Nope, they simply will not work (lack of power supply).
5) Same as above.
6) Radeon 9200. PCI or AGP. AGP with a special gender converter. This converter will not work with any other PCI solution, even PC!
arnljot said:Radeon clarifications.
Please correct what's wrong here, or if it by some strange force in the universe is correct - then confirm:
1) Mediator 1200TX has 3.3V. This enables it to run the more common 3.3V Radeon 92xx cards.
2) Amiga4000 Mediator models have 5V, thus needing special cards which convert 5V to 3.3V.
New questions:
1) Are the two statements above correct.
2) Will a 5V Radeon card work in Mediator1200TX
3) Will a 3.3V Radeon card damage the host or itself in an A4000?
4) Will a 5V Radeon card damage the host or itself in an A1200?
5) If it's not in the product specs, can one look at a Radeon card and tell if it's 3.3V or 5V?
6) Which kind of Radeon card is it the Efika uses, which one has common ground.
1) Correct!
5) Same as above.
