Recommended OS for PPC 1200 tower?
  • Thread starter Thread starter Mendel
  • Replies Replies 11
  • Views Views 1715
Mendel
Finland
kokkola
Okay lets see, here will be my system specs for my tower project if and when I get it running:
Infinitiv tower with 200W standard power supply
A1200 motherboard (of course)
Blizzard PPC accelerator with 060/66 and PPC/240 with 128MB memory. (I´m going to find out if I can go for 256MB)
Some used mediator, I´m still in contact with seller to get the model number and more info...
Voodoo 3
Sound Blaster 128
4GB CF hard drive
4GB CF PCMCIA transfer kit / PCMCIA network card used alternatively as needed.
I´m looking to be able to run 3d accelerated games but still have the option to also run some older amiga native games like Napalm and Alien Breed 3d 2 that require 060 for smooth gameplay.I would also like to run emulator software such as warpsnes.
(for some older classics I will have another system / desktop with 030 and os 3.1)
So, first of all, what operating system should I choose? Amigaos 4.1 for classics or something older? Does the Amigaos4.1 break backwards compatibility to such an extent that I should use some kind of dual booting (like different cf cards for different os versions?)
Local merchant is selling amigaos4.1 classic for 132 euros, is this fair price for it?
I would suggest using Classic Workbench OS3.9 disable the copper, cyberbugfix and then install the mediator drivers off the MMCD.
This will give you a really nice base to expand on for a great workbench, there are lots of Games/Apps you can install and run on this setup.
Also install WarpDT as this will speed up all your JPG and the such, great for web browsing for example.
I would install OS4.1 Classic on another partition but don't get too excited, although the OS runs very well and looks very smart most apps are coded for the faster Sam/AmigaOne setups and run too slow. It's more of a proof on concept OS ;)
Here's CWB OS3.9 running on my A4000D with Mediator4000D/Voodoo 3:
http://www.youtube.com/watch?v=0bUKGpQe0Ng&feature=player_profilepage
All the best,
Steve.
Stick with AmigaOS 3.9. As stevo said, AmigaOS 4.1 is just a proof of concept, not much to do really under classic PPC systems.
On the other hand, using AmigaOS 3.9 you'll be full with every software you can imagine. :thumbsup:
If you want to have an 4.1-look, then install AfAOS for 68k. This will enable PNG icons, antialiased fonts and some other nice stuff.
Airline Tycoon: no. It is MorphOS only.
Arkanoid clone: no (same reason).
All others seems fine.
That´s great because at 45,50 3.9 will be a lot cheaper too :) I seriously overdamaged my budget by hardware purchases... my amiga project may soon be as expensive as my pc lol :)?
Hehe - MAY?
WILL more like :thumbsup:
In a good way of course :)
John
MorphOS/PowerUp could be worth looking into. Started on the PPC Classics, not a backport like 4.x, so it's actually good for stuff.
Stopped development a few years back, but it's newer than 3.9 so I guess it doesn't matter.
Hardware banging stuff will need you to boot 3.x though.
Is there no way to install classicwb39 without a pc and an emulator and transferring the hard disk to pc? I´d like to try other means if there are any before I unscrew the hard drive and start messing with usb->ide adapters and molexes and all that...
Not really, whilst there may be a complicated workaround I doubt it would be practical.
I think I´m going to install classicwb39 as primary and Morphos as secondary os for the tower setup, since I am getting the G-rex that is compatible with both... and I´ll add some old mac os as a curiosity :)
Need some kind of tutorial link for morphos as I am very confused about how to get started with that.
Best for me 3.9 BB4...... More compatible, stable & reliable. Also you can run more apps & games.
You can try, as Steve saids, the CW 3.9 environment it's a great setup :thumbsup:
In "general" opinion (I think) the OS 4.1 Classic is just to see how this OS can runs but it have incompatibility issues with a lot of hardware :whistle:
For a good 4.1 experience you need a PPC system running from a minimum of 700Mhz -> AmigaOne, Sam440, Sam460, ..... :)
